Egt too low?
Egt too low?
Hi guys, I'm concerned that something is not right with my egt temps. I got a 93 12v with bd 40hp sticks, 12cm turbo with upgraded impellers and horn, (30psi)fuel screw turned into the collar and 3200rpm spring. Timing is advanced 1/8th inch and running thinest injector washers. Truck goes like a bat out of h*ll. but wot only gets me 850 on pyro, maybe 950 if I'm pulling. (post turbo) that seems offly low.
Should I trust it?
Appreciate any input.
Should I trust it?
It's an autometer gauge, and I did buy a new probe, didn't change anything. Power braking gets about 700. The reason I'm concerned is most of you guys hit 14-1500 degreese when you punch it, granted I don't know what injectors their running. Could it have to much timing, 1/8th inch plus thin washer?
46rh non lock up auto, it does have a performance low stall TC
Cody
Cody
So maybe you need to add more fuel to reach your desired 1400 to 1500 deg(1100 - 1200 deg post turbo). 1100-1200 post turbo should be considered a bad thing, not a goal, but that's just me.
I understand what you're asking now. The non lock up converter wont put as much load on the engine as a manual would. The same set up with a getrag will hit 1400-1500. I had the same set up minus the 12cm housing. If your truck is fast and all you can hit is 1200 you have a pretty good set up.
tinknocker827
13
12-04-2013 06:26 PM
Moobesor
02-23-2008 09:57 AM
notpowerSTROKIN
18
11-13-2007 06:54 PM
jmccart
14
11-20-2006 06:45 PM
