My Egt's Are Way Too Low I Think........
Alright i just installed my egt sensor finally, and i think my egt's are too low.
At 80mph crusin speed my egts are at 490.
Idling i am at 250.
Floored i cant get it to pass 780 with the chip in 5.
Should it be getting higher?
I dont have my pump wire tapped anymore though since i just put the new vp44.
But i still have stuff done, look at the sig and tell me what you think. It seems low.
Idling i am at 250.
Actully , in some senses it seems pretty low but not if its in the downpipe, now the injectors really wont affect your egt without the wire tapped, really depends on where your probe is! 300-350 is normal on idle
you can reinstall if you want and just put a plug in the elbow where you drilled originally or just figure whatever you see on your gauge plus 300 degrees like dodgezilla mentioned. It depends how acurate you want the sensor to be.
