Do we need vacuum pumps on this engines?
Old Jun 24, 2011 | 06:34 AM
Exekiel69's Avatar
On My 89 the VP is starting to pull less and less vacuum, I only have one bc I have this on My ford (would not fit with two) but I was thinking, can I just remove them both?. If I do I will provably get one from a PSD.
Btw I have hydroboosted brakes so I don't need it for the brake booster.
Thank You.
Old Jun 24, 2011 | 06:38 AM
Your HVAC system probably needs vacuum to operate, but that could easily be supplied by an electric vacuum pump.
Old Jun 24, 2011 | 06:47 AM
Exekiel69's Avatar
Great, thank You. I'll get the electric pump.
Old Jun 24, 2011 | 08:25 AM
BearKiller's Avatar
A lot of luxury cars have electric vacuum-pumps scattered around on them; any of these would be sufficient to operate the A/C functions.
I ?think? that the hydro-boost Ford diesels also have an electric pump.
Old Jun 24, 2011 | 09:01 AM
jesussaves's Avatar
how are you going to remove your mechanical V/P? I dont use mine as well, i just plugged the hose. but would rather take the whole think off but then my hydraulic lines wouldnt fit?
Old Jun 24, 2011 | 09:12 AM
apwatson50's Avatar
I think there is a 4bt application with an adapter that allows the PS pump to bolt directly to the timing case. In my internet browsing I seem to remember reading this. But I may be making it up.....
Old Jun 24, 2011 | 09:36 AM
JD730's Avatar
You are correct. They were used on 4BT applications in the bread van's. I remember a site being posted here for all kinds of parts for that application and I remember seeing those adaptors for direct bolt on of the power steering pump.
Old Jun 24, 2011 | 03:00 PM
Exekiel69's Avatar
I remove the canister alone and install a small plate with gasket maker to cover the hole.
Old Jun 26, 2011 | 05:49 AM
NE frmhnd's Avatar
That's what I'd do.
Also put in a vacuum pump and tank, with a check valve between the two. That way the pump only has to run when the vacuum gets low.
Old Jun 26, 2011 | 10:52 AM
BearKiller's Avatar
Looking at this from another angle, an old Electrolux plugged into an inverter will make more than enough vacuum to work the A/C switches and also has a real factor, besides probably being free.
Old Jun 26, 2011 | 11:26 AM
NE frmhnd's Avatar
Heck, plumb the crankcase breather into the electrolux, too, while you're at it, help seal the rings up and decrease pumping losses.
Old Jun 26, 2011 | 12:51 PM
barrytransport's Avatar
Only problem is the sweeper bag will get oily and plug up. You will have to change it every other day and have you seen the prices on those things latley ? Seriously guys this is 2011 GO BAGLESS!!! Get a DYSON or maybe even a shark. Anyway it only cost a few bucks for the kit to fix it. and besides you wont have to spend the time wiring up a pump or trying to find the right adapter for the power steering pump.
cbx
May 18, 2009 07:23 PM
samiam4
Mar 2, 2008 11:18 PM
Ilikebikes
Dec 11, 2006 10:13 PM
Ggg
Dec 13, 2004 08:07 PM
