Denny T fuel pin HELP
Old Feb 7, 2009 | 07:51 PM
92 Bob's Avatar
This is to anyone out there that has a Denny T pin. I just got mine in the mail today, was going to put that and a 366 spring in tomorrow. It did not come with a new plastic washer, all the other ones on the market come with a thinner washer. (bully dog, ole smokey,ddp.) Denny is not on line but I will pm him anyway, but can anyone tell me , do I not need the thinner washer with his pin or did he just forget to send it ? Thanks.
Old Feb 7, 2009 | 08:07 PM
peobryant's Avatar
You don't need the washer. I don't have mine, and the majority of people don't have theirs either.
Running without it will not cause any engine harm.
Old Feb 7, 2009 | 08:34 PM
Dave F's Avatar
Yep like he said.
Old Feb 7, 2009 | 10:39 PM
Fred Swanson's Avatar
No washer here, either.
Old Feb 8, 2009 | 02:12 AM
1985cucv's Avatar
take out the washer i dont have mine in it is used to "soften" the impact of the pin
Old Feb 8, 2009 | 03:26 AM
flippy1974's Avatar
no washer here .
Old Feb 8, 2009 | 05:03 AM
Onemoparnut's Avatar
I just took mine out also.
Old Feb 8, 2009 | 10:28 AM
archer39's Avatar
as long as the pin rides where you want it you don't need it. On a stock ground pin like mine it will ride too far thus the reason why i have mine but it is shaved down.
Old Feb 8, 2009 | 11:16 AM
DNRCustoms's Avatar
Well, if your the type that like to record different settings, you can install the new pin with the washer.. Run it for a few days.. Then pull the pin back out and take a measurement of where the wear mark stops.. Then reistall the pin without the washer.. Then drive a few days or a week then pop it back out and take another measurement... You should notice the pin riding up/deeper on the new fuel pin... Or you can just take it out from the start!!!
Old Feb 8, 2009 | 12:26 PM
Ace's Avatar
Ace
I shaved mine several times until the witness mark rode up into the deepest part of the pin, like DNR said. Ended up being about half it's original thickness, IIRC.
Old Feb 8, 2009 | 02:03 PM
CONFEDERATESON's Avatar
This may sound stoopid but does the side of the pin that is cut down go towards the front of the pump or towards the side of the motor? im a little confused
Old Feb 8, 2009 | 02:12 PM
DNRCustoms's Avatar
the cut/deep side faces the front of the motor.
gaberichison
Dec 21, 2014 12:21 PM
WillHill06
Apr 29, 2009 08:34 AM
most
Mar 1, 2009 09:26 PM
The_Head
Feb 20, 2009 10:23 PM
ups132
Apr 4, 2008 02:18 PM
