Fuel leak problem with Denny T Pin
Old Feb 28, 2009 | 11:18 AM
most's Avatar
I put Denny T pin in started leaking fuel out of the vent tube. Disassembled top of pump and replaced oring on guide pin and it still leaks. Disassembled pump again what I found this time was it looks like the Denny T pin lets guide pin taper travel to far in past o ring at full throttle. I do not have the washer between fuel pin and diaphram is that my problem. Has anybody ever run into this before if so, what is the solution. Thax
Old Feb 28, 2009 | 11:42 AM
jesussaves's Avatar
put the washer in
Old Feb 28, 2009 | 03:01 PM
Ace's Avatar
Ace
How far up into the deepest cut of the DennyT is the guide pin running? The washer might translate into a 16th of an inch travel there. May or may not be enough to make a difference, worth a try. Is it a StageIII, StageII or what? Maybe Denny needs to include longer guide pins with the really aggressive fuel pins. Somebody made a longer guide pin out of a drill bit here several months ago....
Old Feb 28, 2009 | 07:12 PM
Oldschooldodge's Avatar
My IP started leaking out of the vent tube after the DennyT stage II pin install. I put the washer in with the pin, and it was still leaking, just not as bad. Backed out the smoke screw and star wheel a little, and the leak has stopped. The truck still runs great, and smokes less on the low end.
Old Feb 28, 2009 | 08:38 PM
DennyT's Avatar
Its a combo of ULSD and the travel of the pin. If the oring is bad it will start to leak a bit, the pin does increase the travel and can aggravate bad o rings.
Dennyt
Old Feb 28, 2009 | 10:06 PM
peobryant's Avatar
This is a problem with most aggressive aftermarket pins, or cuts. Not just the DennyT pin. Just so you know.
Old Mar 1, 2009 | 07:58 AM
RollinCoalSmoke's Avatar
I had the same problem with the aggressive stg. 2 pin. My star wheel was set deep and I raised it a bit and the leak quit. Don't know what the star wheel had to do with it "just was the 1st thing I tried" but solved the prob.
Old Mar 1, 2009 | 09:26 PM
most's Avatar
Put washer in seemed to quit leaking Thanks
gaberichison
Dec 21, 2014 12:21 PM
WillHill06
Apr 29, 2009 08:34 AM
The_Head
Feb 20, 2009 10:23 PM
92 Bob
Feb 8, 2009 02:12 PM
ups132
Apr 4, 2008 02:18 PM
