Dancing Speedometer
Old Jul 2, 2018 | 08:04 PM
GCam's Avatar
Dancing Speedometer
Hey guys, continuing now from this scenario:
https://www.dieseltruckresource.com/...s-good-330390/
I have driven about 4k miles, the speedometer is now dancing, probably a 20-30 mile spread (I am doing 80 and it is bouncing between 90 and 120). From what I have read, it could be the VSS? Any input on this?
Also, will this higher speed reading make my odometer turn faster, or is that separate?
Finally, if it is the VSS and I cannot change it until I return home, about 3500 miles, will I damage anything by driving?
Thanks guys!
Old Jul 3, 2018 | 01:53 AM
Angry Johnny's Avatar
Those things are so easy to change. 5 minutes in a parking lot with a pair of channel locks and it's done.
Old Jul 3, 2018 | 09:36 AM
The speedo reading off usually results in the ODO reading being off as well.
I converted my '95 dually from 4.10 to 3.54 gears but did not change the speedo gear in the T-case.
My speedo reads almost 20% off as does my ODO. When my speedo reads 50, I am almost doing 60 MPH.
Old Jul 3, 2018 | 10:29 AM
cougar's Avatar
I'm having the same problem. I've traced it back to bad wiring between the VSS and the speedo, most likely between the VSS and the connector at the back of the engine.
Old Jul 17, 2018 | 10:12 AM
GCam's Avatar
Any idea where I can get a VSS? OR any speedo related items, I called Dodge and everything is discontinued, closest dealership that has anything is 8 hours away.
Old Jul 17, 2018 | 11:29 AM
NAPA, Auto Zone, Advance, Car Quest, Orielly's, just about anywhere.
Old Jul 18, 2018 | 03:51 PM
N. Besonderes's Avatar
10 Year Member
Have you checked the little adapter gearbox between the VSS and the transfer case? If it's loose or the casing is cracked, it could cause the speedo to bounce. Happened to me.
-Niemand
Old Jul 20, 2018 | 10:27 AM
cougar's Avatar
Mine finally hard failed and was able to determine which wire failed. Ran a new one.
dangerousdan
Apr 24, 2007 09:37 AM
zulusafari
Jul 30, 2005 06:06 PM
Mostwanted
Jul 3, 2003 08:22 PM
adgr71
Jan 14, 2003 01:07 PM
cr1998
Oct 18, 2002 02:43 PM
