Cummins just stopped at idle
That fact that it's a cummins or a diesel has nothing to do with it. I have had it happen over half dozen times on diesel engines. The first time for me was on a nearly new 180HP tractor. It had less than 500 hrs on it and the tractor would start and run for about 5-10 seconds then load the engine and die. The a/c clutch was out and once it ran long enough it would kill the engine.
I have never had one with a real serpentine belt system continue to run, for whatever reason they really seem to bite in.
318 with a V belt. and had it on a slant six. both just squealed till the belt broke before I could get off the road. must be the serpentine belt making the difference.
Well, I really wish I would have taken the serpentine belt off to test it.. Turns out it was the fan bearing… must of been dragging on the engine for quite a while then completely seized….
patdaly (12-16-2016)
Ya I don't think a v-belt would stop any engine, they simply do not have enough surface area and grip to bring an engine to a stop. That's another reason I hate v-belts on any engine they just doesn't last or function like a serpentine belt setup does.
good to hear it wasn't anything really $$ or major.
You where looking at a tow anyway, unless you carry a spare fan hub with you.
Glad it was a simple and fairly cheap fix.
thrashingcows (12-15-2016)
I had a bearing in a year old alternator crap out in my '77 Ford truck causing the rotor to hit the stator. Sounded like I had multiple rods knocking. I was freaking out thinking I trashed the engine (400M) and my buddy Mark sussed out the alternator by listening to various components through a long screw driver. Like a poor man's stethoscope.
On the plus side a simple fix is generally preferable!
Jeeprat
10-07-2009 10:25 AM
Stainless
07-10-2008 03:21 PM
