cross over steering tie rod end
When I talked with the guy he sounded pretty kool I would still give it a try and just explain what you have and see if he will give you the number for the end Worst case he will say No best case he say's Sure glad to help .
I think I've figured out what the deal is. SJ sent me the wrong pitman arm. The small (top) hole on the pitman arm is only 1/2" and the large (bottom) hole is ~5/8". The factory drag link bolt is 5/8". That's not going to work.
i was told to get a wj pitmon arm and that the hole would have to be resized for the tie rod end to fit also will need to remove clocking keys enable to install where iot needs to be for crossover
Look up the tie rod & drag link identification in the below link:
http://www.partsmike.com/index.php?sc_page=50
http://www.partsmike.com/index.php?crn=240
And yes the wj piman arm needs to be resized for appropriate TRE and splines cut out to fit.
gscmiller
Sep 2, 2011 08:19 PM
hoffdog
0
Sep 21, 2010 08:53 PM
txfiremedic
Jul 22, 2009 11:01 PM
ddestruel
Dec 7, 2008 06:37 AM
