Crewcab update...
Old Oct 26, 2013 | 02:55 AM
  #211
Now the fun part. Install the brackets and try and get all the measurement s to line up... I spent a couple hours running back and for to the computer to check all the measurements. I eventuallt got it all blocked up and in position.
I then noticed that the Driver side rear most upper hole in the bracket lined up almost perfectly with the center hole left by a rivet I pounded out.
The passenger side was off just a little....
I decided to install bolts and see where my measurements would fall.
So with the main center cross member bolted in using those two holes, All my measurements are within a 1/16th to 1/8th...and some are dead on. Think I can live with those measurements. So tomorrow I will double check the measurements one last time, then start drilling.
Old Oct 26, 2013 | 07:21 AM
  #212
Very nice..... When this is all done, you can push those boulders out of the way at the house next door...
Well, that's what you do with these old 4x4 trucks, right ?
Old Oct 26, 2013 | 09:33 AM
  #213
mknittle's Avatar
Once I took a few dozen measurements I disassembled everything and re-installed the forward cross member in the 84 frame. But before I got too far into that I decided to mount, and drill the needed hole for the steering box brace.
Installed....and punched
Drilled out to about 3/8"....
And then the final drilling was done with a step drill...worked like a charm!
Is that a steering box brace? neither of the two we have has one.
Old Oct 26, 2013 | 09:41 AM
  #214
mknittle's Avatar
Moving right along now. Looks good! I wish mine were that far along.
Old Oct 26, 2013 | 10:38 AM
  #215
Yes that's a steering box brace. They were never really that common.
There was a company that used to reproduce them, but they are currently out of stock, and they have no plans to make another run on them.
I was lucky and found an original one off a Ramcharger on E-bay.
Old Oct 26, 2013 | 12:00 PM
  #216
m-o-p-a-r's Avatar
looking sweet! I really need to learn to paint my stuff, It looks so nice!
Old Oct 26, 2013 | 12:25 PM
  #217
Just a little sanding, and a rattle can Gloss black paint job....not too fancy.
Old Oct 26, 2013 | 12:32 PM
  #218
So I've been tearing apart my NV4500 the last couple nights. Found a couple issues.
One was with the 5th gear that I ordered from Quad4x4. I decided to see how it fit on the new 4wd main shaft but it would only go up to the threads for the nut. Not over and onto the splines...***!! Turns out I got the right package, but the wrong part inside. I have to say though Roy down at Quad4x4 has been more then helpful in fixing this issue, and quickly!!
Second issue is when I got my 5th gear clutch and gear assembly off the counter shaft, a couple teeth fell off the inside of the clutch!
So looks like I will be needing a new clutch/cone assembly for 5th gear. I see there are aftermarket units...anyone run one of these? How do they stand up?
I can get an NOS OEM unit from Quad4x4...but they are 4x's the price of the aftermarket units!! I personally think I will go with the aftermarket unit. Since I will never be turning up my motor to make crazy HP or Torque. And I drive, and shift very easy.
Old Oct 26, 2013 | 12:40 PM
  #219
Next problem I'm having is with removing the bearings. Anyone who's done this in there shop/garage have any tricks to share?
I had to putt the cage and rollers off the counter shaft bearing so I could swing it up and out of the case.
I don't care about the 2wd main shaft...it's toast anyway due to the 5th gear failing. So I was just going to cut them off. But the counter shaft front bearing is sunk down within the gear...not sure how I'm going to get that one out?
You can see it in the pic as I'm lifting the the cluster out.
Old Oct 26, 2013 | 12:42 PM
  #220
Another question to guys who have done this 2wd to 4wd conversion, and swapped all the mounts and brackets. What size bolts did you use to re-attach everything? 7/16 or 1/2 grade 8 bolts, nuts and washers?
Old Oct 26, 2013 | 09:31 PM
  #221
mknittle's Avatar
"They have no plans to make another run on them". That's ok I think I know somebody that can make one.
Old Oct 26, 2013 | 09:42 PM
  #222
mknittle's Avatar
The stock crossmember bolts are 7/16 grade 5. but I bought all 1/2 grade 8 for the whole shooting match. I get them by the pound nuts washers and bolts.
Old Oct 26, 2013 | 09:55 PM
  #223
Not sure what the rating is on the cold rivets. But they are a 7/16. If I go 7/16 - Grade 8 with hardened washers? I will check with my commercial truck tech/ inspector friend of mine on this one.
Old Oct 26, 2013 | 09:57 PM
  #224
mknittle's Avatar
The cheapest(and easiest) way would be to take it to a machine shop and have it pressed off. unless you know somebody that has a gear puller and bearing splitter. But that can be a wrestling match.( been there done that)
Attached Thumbnails Crewcab update...-gear-bearing-separators-puller-set-separator-bng.jpg
Old Oct 29, 2013 | 08:54 AM
  #225
mknittle's Avatar
How did you do on the transmission?
