Clutch Fan OIL???
Old Jun 26, 2010 | 11:37 AM
jesussaves's Avatar
Clutch Fan OIL???
I took my fan off and laid it on the ground, the next morning oil was everywhere underneath it where do I add more and what kind of oil???
Old Jun 26, 2010 | 12:33 PM
jimbo486's Avatar
should be no oil in the clutch. did you take the hub/bracket off the block with it? if so, the hub bearing is sealed. maybe that's where the oil came from?
Old Jun 26, 2010 | 12:34 PM
BigIron70's Avatar
Cummins Guru
Sorry, time for a new clutch fan that one is shot.
LEAKS
Viscous fan drive operation is not affected by small oil stains near the drive bearing. If leakage appears excessive, replace the fan drive unit.
VISCOUS DRIVE
If the fan assembly free-wheels without drag (the fan blades will revolve more than five turns when spun by hand), replace the fan drive. This spin test must be performed when the engine is cool.
Old Jun 26, 2010 | 12:35 PM
jimbo486's Avatar
if that's the case, get the new & updated one from the dealer. supposed to be quieter. the new fans have a slightly different pitch to the blades as well.
Old Jun 26, 2010 | 01:34 PM
You let all the good out of it. That's why you should always stand the fan on edge when you take it off the truck. I know, I know, that's real helpful information now!
Old Jun 26, 2010 | 01:44 PM
jesussaves's Avatar
so will a good one leak as well? I didnt have any problems with it? I thought mine was good?
Old Jun 26, 2010 | 01:46 PM
Yeah, a good one can be ruined by laying it down.
Old Jun 26, 2010 | 01:51 PM
jesussaves's Avatar
wow that was an expensive mistake, So i guess the dealer is the best place to get a new one and I should get the whole assembly?
Old Jun 26, 2010 | 01:57 PM
You can get one from the local parts store, I don't think it's critical to get OEM. No need to buy a fan if yours is in good shape. Check it closely for cracks around the rivets.
Old Jun 26, 2010 | 02:26 PM
apwatson50's Avatar
If you are towing anything more than a motorcycle trailer, get an oem. I haven't had good luck with parts store ones. They don't lock up near as soon or as good as an oem.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
