Changed lift pump, truck runs smoother?
Maybe it's all in my head, but the truck seems smoother at low RPM and idle now that I put in a new lift pump. The old one had a film of fuel on it all the time, but I couldn't find a leak. I replaced it with a Delphi unit from US Diesel Parts this morning, bled the low pressure system and fired it up. I noticed the smoother idle right away. I'm finding this confusing because I read on previous postings that when the lift pump on 1st gens dies, you notice a power loss at high rpm, but the truck runs ok at low speed. Did I just have an air leak that I've fixed while installing the new pump?
Re:Changed lift pump, truck runs smoother?
Did you take any pressure readings on the old pump to confirm that your pump was bad? Also, when I got my lift pump. Cummins gave me 2 gaskets. Did you put both of them in? Just wondering.
No, I didn't test pressure, I just took the film of fuel as a sign that something was wrong and changed the pump as a precaution. The priming lever worked and I wasn't making oil, so the pump probably made some pressure. The Delphi pump only had one gasket. I don't know why GM is making lift pumps for a 10 year old engine they don't use, but the price was right, $36 if I recall correctly.
I just ordered one too. Mine is going on 13 years old. It's not seemingly giving any trouble but with the camper pulling season coming on, I don't want to get stranded because I didn't replace a $44 part. I'd feel pretty dumb about then
Plus, if I'm not getting enough pressure to the injector pump, it could damage it, couldn't it?
I just replaced my lift pump last weekend. Everything was running good, but I was installing new injectors, so I figured I'd replace the original lift pump.
I put in a Carter. $66 cost to my son's repair shop. One gasket. The old pump had been leaking a little oil thru the bottom of the gasket.
Truck does run smoother and idles about 50 rpm higher, but I think that's because of the new injectors, not the lift pump.
Jay
Jay
Seems strange but I noticed the same on my 93. My injector pump took a dump so i replaced it also from US Diesel. My fuel line was near impossible to loosen ,it actually started to spin the two halves of the lift pump comming apart. I used one gasket with some RTV and no problems.
Apache
Apache
clayne100
20
Nov 1, 2006 02:44 PM
big jimmy
Jul 21, 2006 01:33 PM
dssimecek
Jan 24, 2006 09:49 AM
