New alternator, now smoother running?
Old Jul 19, 2006 | 11:00 PM
big jimmy's Avatar
To add to the alternator databank here is my experience:
It was a slow death that showed up in a low charge on the dash gauge but it came on so slowly and sometimes went away I hardly noticed. Until the smoke and burned wire smell and a total volt crash. Then that went away also but seeing the writing on the wall I switched it out.
I swear my truck is running smoother now. Its just an overall feeling. Could the low voltage have had some side effects, even with good batteries?
Big Jimmy
Old Jul 19, 2006 | 11:44 PM
I PASS GAS's Avatar
If it were a 24 valve, it's say the low voltage running the electronics could cause that. Being you have a 12 valve, and it's strictly mechanical, I serisouly doubt it's running smoother...at least because of the alternator.
Old Jul 20, 2006 | 01:02 AM
mvanhelden's Avatar
Mybe the fried alternator was putting a drag on the engine?
Old Jul 21, 2006 | 10:28 AM
San Felipe Bob's Avatar
Thumbs up Yes
Our 2nd gen. CPU uses many sensors.(most are in the transmission.)
The sensors work with 13.8 volts +or-.
If your alternator goes bad it will cause all kinds of problems.
My alt. went bad and it caused my transmission to shift crazy.
It did not effect the Engine.
In fact I drove from New mexico to So. Cal. without any charging from the alternator.
Good thing I am running 2 1700 odyessy batteries!
New alternator = new truck!
SFB
Old Jul 21, 2006 | 11:14 AM
DieselDaze's Avatar
It may be a stretch, but due to the fuel shut-off solenoid being electronic, could it be that as the voltage dropped, your fuel shut off solenoid was not lifting all the way and in turn, you were not getting all the fuel?
Now, with good voltage, your getting slightly more fuel to the engine.
Rich
Old Jul 21, 2006 | 01:33 PM
big jimmy's Avatar
Rich
Bingo! The way it was driving a week or two prior to the meltdown was very much like fuel starvation. This was at light throttle.
clayne100
20
Nov 1, 2006 02:44 PM
dssimecek
Jan 24, 2006 09:49 AM
BC847
Nov 7, 2005 08:12 AM
planetdell
Aug 24, 2004 08:45 PM
wannadiesel
Jan 16, 2004 03:20 PM
