Smoother ride, rotated and balanced.
Old Jan 23, 2006 | 12:18 PM
dssimecek's Avatar
With only 20 K miles on the truck, when I had it serviced at the dealer in Spring TX, service mgr ask if the tires had ever been rotated or balanced. Never had it done, the dealer in Scotsdale AZ said they dont rotate the dulleys.
The rotate and balance made a smother no viberation, or rumble.
Just thought I would pass it on, for what it is worth.
Davey
Old Jan 23, 2006 | 06:46 PM
infidel's Avatar
This is why I use tire balancing beads, tires are always perfectly balanced.
Most most people don't realize that a tire's mileage rating only applies if they are rebalanced every 15k
More info on balance beads> http://www.innovativebalancing.com/index.html
Old Jan 23, 2006 | 06:57 PM
jta's Avatar
jta
How do you like the beads? Did you balance the tires and then put the beads in or do you just use the beads? I read that you can do it either way. I have the beads and plan on using them only.
Old Jan 23, 2006 | 07:30 PM
J BODY's Avatar
I rotate and balance the tires on my 2500 at every oil change (6 to 8 K)......and by the way, I HATE doing rotate balance on a dually. That can be a back breaker.
Old Jan 24, 2006 | 09:49 AM
infidel's Avatar
Love the beads, use them on all my rigs and will never go back to the old way. I use beads only but have the shop check for roundness on new tires on the balance machine. They do this for free.
Beads are the only way to go.
southerman
Jun 30, 2012 03:35 PM
Sixpack73
Jan 22, 2007 03:19 PM
clayne100
20
Nov 1, 2006 02:44 PM
BC847
Nov 7, 2005 08:12 AM
planetdell
Aug 24, 2004 08:45 PM
