Calling all Custom EDM Injector Guru's/Users - Please Help Me.
Old Jan 15, 2009 | 07:51 AM
  #31
JAyers's Avatar
Phillip i never could get my 18's to burn clean at an idle, even with the 12mm pump. My 16's are really close to being clean in the summer time but if you step away from the truck and loookk reallly close you can still see it. Its the nature of the beast in my mind.
Old Jan 15, 2009 | 12:15 PM
  #32
tcs 91's Avatar
my ddp IV's get a little hot on the exh when towing up hills. i just turn on the snow. straight water when towing. cools right down then i turn it off on the other side. i'm a believer and it's easy. tc
Old Jan 15, 2009 | 05:57 PM
  #33
randyswelding's Avatar
how much timing can i run then with em,im lookin at jumpin a tooth(dont know which way yet,asumin clock wise) and stock at the mark on the case to start with,too much?
Old Jan 15, 2009 | 06:02 PM
  #34
Mine was pushed to the head before I jumped a tooth. When I jumped a tooth, I put a timing tool in the pump so I would know where to start. That turned out to be the stock timing marks, they were almost perfectly aligned. I'm now about 1/16" past there, it sounded spooky at 1/8, and past there it would surge under light throttle at highway speed.
Old Jan 15, 2009 | 06:09 PM
  #35
ok how do i get a timing tool and how do i use one? what do you mean that it turned out to be the stock timin marks,they were almost perfectly aligned,and now a 1/16 past there,it sounds spooky at 1/8.wanna?sorry i havnt figured out to do the quote thing yet
Old Jan 15, 2009 | 06:23 PM
  #36
Sites that sell VW diesel parts usually have good prices on the timing tool kits. You use it by checking plunger lift @ TDC on #1.
When I jumped my timing gear a tooth, I put the truck on #1 TDC and installed the timing tool and wrote down the reading on the dial indicator. Then I jumped the gear a tooth and moved the injection pump until the dial indicator read the same as before (so the timing was the same). That just happened to make the stock timing marks line up. Then I bumped it about 1/4" and strapped it to the dyno. I wound up backing it off some later due to driveability issues and because it just sounded scary to me.
Old Jan 15, 2009 | 06:30 PM
  #37
so then there is more to just jumpin a tooth to this i see.did you go clockwise when you did it. and im runnin stock timin on teeth but bumped up and my timin pin under the pump wont go into the slot on the teeth is that due to havin the pump moved
Old Jan 16, 2009 | 05:28 PM
  #38
No, I just did it that way so I'd have a known point to go back to if I didn't like it.
Yes, the gear goes clockwise (as viewed from in front of the truck) one tooth.
No, either the pin is broke or stuck.
Old Jan 16, 2009 | 07:32 PM
  #39
ok then it got stuck again or it could have broke cause it will move a very little,thanks wanna
DodgeRamdiese01
Nov 14, 2009 10:13 PM
stoneage
Feb 11, 2009 04:08 PM
DodgeDemon
Jun 30, 2007 01:44 PM
GMScott
Oct 21, 2004 03:01 PM
97CTD
Feb 24, 2003 05:00 PM
