Calling all Guru's
Old Feb 11, 2009 | 11:46 AM
stoneage's Avatar
Calling all Guru's
I need to ask help from anyone who might know wich direction to point. Here's the deal. I've got a 2001 3500 with some sort of fuel issue. It was running fine when I got to the gravel yard, got loaded up, tried to leave and truck lost power. Let me clarify. Truck starts, idels fine, but when you press the accelerator the truck starts loading up, or "dieseling out" at about 1100 rpm. checked the code from the ignition and it wAS P1693. I replaced the lift pump hoping that would do it...... still same thing. It has a power max 3 unit on it that appears to be functioning corectly. The truck was stranded about 20 miles from home, so I made the decission to try the drive. From 900-1200 rpm it ran as normal. Any more and it would load up.
Is this a bad vp44? I was told that if the injector pump goes the truck will not run at all, is this true. Could the trotle possison sensor be to blame? If so how would you check it.
Some help to lead me in the right direction would be great.
Old Feb 11, 2009 | 12:17 PM
mishkaya's Avatar
Have you tried running the truck without the powermax to see if it makes any difference?
mishkaya
Old Feb 11, 2009 | 12:35 PM
johnh's Avatar
probably the tps
Old Feb 11, 2009 | 04:08 PM
patdaly's Avatar
P1693 is a companion code telling you the ECM has a stored code, you need to get it read.
Sounds like "dead pedal", look for a P0216 for the VP ( there are others as well, I don't know them all )
If it were mine, I would be saving for a VP.
Hillbilly5.9
Mar 1, 2009 07:30 PM
justagoodolboy
Jan 16, 2009 07:32 PM
DodgeDemon
Jun 30, 2007 01:44 PM
GMScott
Oct 21, 2004 03:01 PM
97CTD
Feb 24, 2003 05:00 PM
