A/C Fan on high quit working
Old Jul 26, 2010 | 08:59 PM
TJE's Avatar
TJE
I did the write up Jim Lane posted in the sticky on how to get your blower fan to blow faster. Well going down the highway this evening the fan quit blowing on high. It still blows on low and medium, but not on high. Any suggestions?
I looked and made sure everything was still connected, and it is. I don't know where to start!
Thanks, Tony
Old Jul 27, 2010 | 03:40 AM
Jim Lane's Avatar
Thanks, Tony
Tony,
If you followed my diagram here is the order in which I would check:
A) Using a voltmeter or a test light check at Term #30 of Relay K-2 and see that there is a good 12-volts. If there is not check your fuse and connection to your battery.
B) With a jumper wire connected to the battery (+) connect the opposite end to the relay Term. #85 or whichever terminal you used for (+) and see if the relay pulls in and the blower runs.
C) If the relay clicks but the blower does not run and you have 12-volts at the relay Term.#30 using a jumper wire connect Term. #30 to Term. #87 and see if the blower runs.
If it does run then your relay is probably burned out, I have a 75-amp relay on mine.
D) If the relay does click and the blower runs when the jumper wire from the battery to Term. #85 is connected then using your voltmeter or a test light connected to the wire that is connected to Term. #85 see if there is 12-volts when the IGN is on and the blower switch is set on HI.
Check it out following this procedure and it should be easy to find the problem,
I am betting on the relay being bad.
Jim
Old Jul 27, 2010 | 07:21 AM
TJE's Avatar
TJE
Originally Posted by Jim Lane
Tony,
Jim
Thanks Jim. I know nothing of electrical stuff.
Regards, Tony
Old Jul 27, 2010 | 02:52 PM
deanhinsley1963's Avatar
probably the blower motor fan switch in the dash. they do that every now and then will blow on every position except high,try while it is on to go from lo to hi fast and fairly hard and somtimes it will go to hi. Thats what mine do'es anyway.
Old Jul 27, 2010 | 06:42 PM
whosdunit's Avatar
I'm with 1963, my a/c sw., has reached that point , i was goin to pull my sw., but my a/c 's quit....again...then it cools then quits....again . did anyone else have to take their pass., side fender off to get to the compressor swichamuthing?,up behind the glove box where you first ncut a hole ,thinging you could get to it that way.
Old Jul 27, 2010 | 08:53 PM
TJE's Avatar
TJE
The high wire in the dash has been disconnected. I have mine wired according to the diagram posted above.
Tony
Old Jul 27, 2010 | 09:33 PM
whosdunit's Avatar
1963 ---I think i'v seen your trk., around town here (HUGO),I'M JUST WEST EDGE OF TOWN.Look me up,. TJE you s.e. okla.???
Old Jul 28, 2010 | 08:07 AM
TJE's Avatar
TJE
I'm in the Claremore, Tulsa area.
95ram
Dec 8, 2009 07:31 PM
big jimmy
Jul 7, 2006 01:33 PM
j28s
May 26, 2004 03:02 PM
j28s
May 24, 2004 08:34 PM
Garz
Nov 17, 2002 02:02 PM
