Brake line source?
Old Mar 16, 2010 | 09:19 AM
Josey88's Avatar
Brake line source?
I need the metal brake lines which run from the wheel cylinders to the block on the rear axle. Our local Dodge dealer was closed so I am looking for any suggestions. Thanks.
Old Mar 16, 2010 | 09:40 AM
Tater93's Avatar
I bought a Stainless Steel set to do the entire system from a company called Classic Tube for 225 bucks. They make them out of plain steel too. I don't know if they sell individual lines though, they may only sell kits to do the whole vehicle.
Old Mar 16, 2010 | 09:59 AM
huntinguy's Avatar
I got mine from O'rilies but Advanced has them too.
Old Mar 16, 2010 | 10:09 AM
kensmachine's Avatar
I have bought from Classic tube and if you want just the axle set they will sell it to you Ken
Old Mar 16, 2010 | 10:42 AM
Josey88's Avatar
Thanks, When bleeding the brakes, the bleeder valve broke off flush with the wheel cylinder. So a simple job has turned into a whole brake job which, after removing the drum, was needed anyways. Does anyone know what size the nut is which is on the axle?
Old Mar 16, 2010 | 11:25 AM
Tater93's Avatar
I don't know off the top of my head. If no one else chimes in till I get home from work I'll check my socket and let you know.
Old Mar 16, 2010 | 11:45 AM
Josey88's Avatar
Thanks Tater93, I appreciate it. York, Pa I was through there several times in Nov-Dec for work. That is pretty country all through there.
Old Mar 16, 2010 | 12:09 PM
82F100SWB's Avatar
The rear axle is 2-9/16" round hex.
Old Mar 16, 2010 | 12:17 PM
ppiggppenn's Avatar
ditto 2 9/16" on my 2WD, .... got the socket from UAP/NAPA for around $15, .... don't use air ratchet for off or on: my 1/2" drive hole is nearly rounded out ...
Old Mar 16, 2010 | 06:15 PM
bariley's Avatar
bought a 20ft roll, bent and flared my own, looks as good as pre-bent ones.
Old Mar 16, 2010 | 07:32 PM
TIMMY22's Avatar
That's what I did. I got the poly coated stuff. Not supposed to rust. Or rust as fast
Old Mar 16, 2010 | 09:20 PM
RuralCruiser007's Avatar
On my rear end it was 2 1/2". I use the 2 9/16" round on the front.
Old Mar 17, 2010 | 11:42 AM
Josey88's Avatar
Thanks all for the input. I "thought" I knew enough from all the trucks I've owned thru the years. However, the drivers have always been 1/2 tons Dodge, Jeep, IH and this 3/4 is a whole different animal. Makes me feel like a complete noob.
weiercd
Nov 22, 2013 07:54 PM
GSP
Sep 23, 2008 09:49 AM
Fallfork
Apr 7, 2008 12:10 PM
convertiyota
Dec 13, 2004 09:42 AM
SolidJunkMM
Oct 21, 2003 06:14 PM
