Blower fan doesn't work HELP
Old May 1, 2007 | 06:00 PM
pred's Avatar
OK here is what i know
Blower fan doesn't work on any speed
Have 12v to fan
Plugged in new fan tested on batt +- works fine
Will not work at connecter for old fan
12v at connector
0 volts at all 4 wires at fan speed switch
? What is wrong? What am i missing???????
Fuse good!
vacuum controlls all work
Peter B
I Have no AC!!!!!!! HELP
Old May 1, 2007 | 06:03 PM
dieselJon's Avatar
You could do what I did after I found the switch coupler melted, hard wire a on-off switch so I have all or nothing! The biggest wire is the feed and the bottom wire is the high speed setting. Hope this helps,
Jon
Old May 1, 2007 | 06:11 PM
BC847's Avatar
1st Generation Admin
See if this helps ~ https://www.dieseltruckresource.com/...0&postcount=11
EDIT ~
Wire Color/Coding
10TN is a 10awg wire that's Tan in color. 16BL is a 16awg that's Blue in color. 12LG is a 12awg wire that's Light Green in color. . . . Get it?
The prefix: C7 or C12 might be Circuit 7 or 12 of a given group. Not sure of that.
Old May 1, 2007 | 06:18 PM
jogl's Avatar
First thing is to figure out how you can have 12V at the connector with no voltage at the switch.
I know that does not answer any of your questions. But further investigating seemingly contradictory bits of evidence often leads to root causes.
Keep going,
JP.
Old May 1, 2007 | 07:43 PM
Sounds like you have no ground at the fan. Clean and retighten the RH headlight ground.
Old May 2, 2007 | 07:20 PM
pred's Avatar
Cant find a ground near front pass side headlight, But installed a ground from Batt to body, still no fan
Ran a + and - from batt to old fan, it works fine that way, Havent had time to do all the tests stated above,,,, Need wiring diagram, anyone here have one on cd they can email to me?
Thank you!
Peter.
Old May 3, 2007 | 04:33 PM
ofcmarc's Avatar
Check the switch. If it dosen't work at all it is usually the switch (assuming the motor is good). If it only blows one speed it is usually the resistor.(behind the glove box ~$15 @ the dealer)
Old May 3, 2007 | 06:58 PM
pred's Avatar
The blower will work if wired hot to the battery,,, It works on NO speeds
And it went out all of a sudden, I dont have an extra switch, But i think i can scare one up at the bone yard, Thanks.
Peter.
Jim Lane
Apr 5, 2020 06:03 AM
CactusPete
Aug 4, 2012 11:26 PM
samboats
Nov 29, 2009 07:32 PM
big jimmy
Jul 7, 2006 01:33 PM
NHDiesel
Aug 20, 2005 06:01 PM
