Big Single
Old Nov 16, 2005 | 07:26 PM
12vchevydually's Avatar
Big Single
I was just wondering what are some big singles people have run on a First gen. And what are there results. I have been starting to turbo shop, and just wanted to hear what people have tried. thanks!!!!!!!!!!!!!
Old Nov 16, 2005 | 09:08 PM
gman07's Avatar
Well, I know bgilbert has a SP66 from HTT, but I havent heard any numbers yet... He should pop in here soon. I havent heard of many people running a B1 series turbo on the 1st gens, but I'm not sure why.
Old Nov 16, 2005 | 09:15 PM
Stomp's Avatar
Because most people will tell you that a ve pump cant put out enough fuel to spool a larger single, but we all know that is false.
Stomp
Old Nov 16, 2005 | 09:42 PM
Stomp I know you love your twins, but what is the largest single you would think about running without a kta head?Rock on "1st gen's have some fuel"
Old Nov 16, 2005 | 11:30 PM
Stomp's Avatar
Well I ran my HX40/16 as a single and it worked just fine. I put down 419hp. It would still get hot though. I think you could get a way with a sledpuller66 with a smaller exhaust housing to help with spoolup. Or a phat shaft 64 or 66. A B1 would also do fine. Pump would have to be maxed though. The biggest thing is there is going to be some lag no matter what.
Heck after I broke my pump we put on a totally stock pump and it made it home. It was a pig turbo's didnt even try to light 850* max. With my old stocker maxed out I could get to 1100* and sometimes 1200* with the twins.
Stomp
Old Nov 17, 2005 | 07:20 PM
bgilbert's Avatar
I wouldn't be afraid to put any of the big singles available on a 1st gen with 12mm pump. Just depends on what you consider lag, what your intended use of the truck is etc. A HX40 is good til about 400rwhp, then egt's get hot. If you are wanting more hp for sled pulling, I'd pass on the hx40 and go with a B1 or the like. B1's, HTB2's etc are based on a Schwitzer s300. Tougher than the hx40.
Old Nov 19, 2005 | 08:55 AM
Yeah, I am not afraid of some lag, because when it lights watch out. I was Thinking about JR's Baby 55. Would that be too much?
Old Nov 20, 2005 | 10:05 AM
This would be with the usually pump mods. Gov spring. Ground Pin and afc lever. Or do you all think I am crazy!!!!!!!!!!!!!!!
Old Nov 20, 2005 | 11:22 AM
signature600's Avatar
Wanna try a full bore B1?? I've got one available, if you want to try it!
PM me, I'm too close for you not to
Chris
Ramdriver15
17
Jul 15, 2007 09:03 PM
Grimwulf99
23
Feb 16, 2006 06:17 PM
Ocmechanx
Jan 19, 2006 06:14 PM
getblown5.9
15
Jan 26, 2005 12:23 AM
turboost
Sep 19, 2004 07:24 PM
