real big single????
Old Jan 21, 2005 | 12:49 PM
getblown5.9's Avatar
real big single????
what would it take to spool something like a hx-55 or one of the really big singles out there...
im guessing huge injectors and propane and/or nitrous?
Old Jan 21, 2005 | 01:35 PM
signature600's Avatar
JR Adkins!
He makes an HX-55 Hybrid that is pretty wicked for a big single.
Do a search on it
Chris
Old Jan 21, 2005 | 01:48 PM
what does it take to spool it tho...once you go that big im sure the lag is killer on it
Old Jan 21, 2005 | 03:02 PM
BigBlue's Avatar
You'll definately need more fuel than your pushing now.
Old Jan 21, 2005 | 04:03 PM
lets be more specific,
will i need a "hot rod" vp-44, what size injectors will i need, what time of box will i need, timing and fuel, or fuel alone
also, will i need to o-ring the head, head studs are a given for anything over 45 psi
even with those mods, will i still need to add propane or nitrous to spool it quicker?
i might have a deal on one locally, real cheap, and i need to know how much ill have to spend in order to make it worth while, if i have to rebuild my entire engine then forget it, i'll go with a hx-40
Does anyone out there know what it takes to run turbo this big by itself??
Old Jan 21, 2005 | 04:57 PM
BOYDO's Avatar
EDM 100 hp injectors, will work great with a HX40, add a comp box for good times.
24valvepuller's Avatar
It will take quite a bit of work to spin something like that. O-ring either the head or the block, I would run like a stage 7 or 8 injector 200 hp plus then a drag comp or redline box. something with lots of fuel and lots of timing and then to top it off a dual disk clutch from one of the big two, EEP or Haisley. If you can do the work yourself prolly about $4000-5000
Old Jan 21, 2005 | 05:41 PM
Moose10's Avatar
"I guess its pointless as of now to worry about it, i am selling the truck ASAP as its no longer affordable on my budget"
Dude I thought you were selling your truck ?
Old Jan 21, 2005 | 10:37 PM
SjLingenfelter's Avatar
We had a JR55 on our race truck with DD5 with a DRAG COMP and it was laggy but it had some great power behin it plus LOTS of smoke. I mean we had smoke at idle almost. But some people run a 55 with big injectors for single chargers when pulling and most people use HT3b with 22-26cm housing for twin setups. Like a common twin setup is a HT3b/22 with a Hx35/14 which is a good set for DD5.
Old Jan 22, 2005 | 12:09 AM
truck is not being sold...god worked in a mysterious way...that morning i posted the comment above and a classified on one of my local forums...i got a phone call a few hours later, my insurance was being dropped substantially each month
then my boss came in with my paycheck, i opened and noticed a decent raise...all in the day i thought i was selling my pride and joy.
any will not be installing this set-up on my truck, the info was needed to fight a battle with a ford guy who knows as much about diesel motors as i know about quantum physics
as for my set-up...hx-40, stage 3 injectors (DD's or mach's), comp with no wire tap, SBC con ofe
Old Jan 22, 2005 | 05:09 PM
Mike Holmen's Avatar
The Guru
To help to spool what ever turbo you buy tap the wire on the VP box. The extra fuel helps wake her up. Its like night and day differance between the two. With the injectors you listed, the hx-40 is a better turbo and will out perform a HX-55 in the mid range boost levels. My thoughts are a HX-55 would be pretty laggy to drive around without lots of fuel. At full spool shes great the HX-55 and would out perform a 40, but highway drive and around town its wouldn't be so much fun but that depends on your foot. Twins are so sweet
Old Jan 22, 2005 | 06:22 PM
Trashdawg5050's Avatar
getblown5.9 you have a PM
Old Jan 23, 2005 | 07:01 PM
2broke2smoke's Avatar
hmmmm ... hate to disagree with all the experts but
my HYBRID 55 is great
i'm running dd jammer 4's
no smoke at idle
can run all day with low smoke (if i try), less than my first gen with the pump turned up
just the injectors will spin the turbo to 28 psi
my wastegate is set at 43 ... with drag comp on it'll flip up to 45
this is my daily driver
505 horse out of a stock block/head with this charger says it all
over on tdr there was a recent post about the little 55 that stated 40 psi preturbo at 50 psi of boost ... that's better than some twins
Old Jan 24, 2005 | 05:32 PM
AWray's Avatar
Anybody know what mods it takes on a 12V to make one of J.R.'s 55's driveable on a daily basis? More specifically, on a 160hp P7100. If it is not possible with a 160 pump, how many cc's of fuel do you need to flow to make a 55 a daily driver?
Old Jan 25, 2005 | 09:36 PM
smittybuilt's Avatar
give J.R. a call, he is a great guy to talk to and his 55 hybrid is (in my opinion) the best single to sledpull, tow, and just have a good time driving. you do have to have some fuel to move it but if you don't have alot of fuel ask him about his smaller chargers. here is his number:317-281-3130.
