To all you guys who have relayed your headlights
Old Dec 26, 2006 | 12:03 PM
IraPatterson's Avatar
Hey Everyone,
Just really quick, what is the part numbers on the 30amp relays you used to wire up your headlights with?
Thanks!
Old Dec 26, 2006 | 12:19 PM
04ctd's Avatar
radio shack or advance should have regular 30 amp relays for car use $5 or so?
Old Dec 26, 2006 | 02:36 PM
Rammer64's Avatar
Bosch 30-40 amp
Ask for the Bosch 30 or forty amp relay. I have to admit, I find they work the best.
http://cgi.ebay.com/ebaymotors/AUTOM...QQcmdZViewItem
http://www.tessco.com/products/displ...32&eventPage=1
http://www.bcae1.com/relays.htm
Old Dec 26, 2006 | 06:53 PM
bigragu's Avatar
Is this mod for the really bright lighting by combining low and high beams together? If so, please lead me to a step by step schematic!
Old Dec 26, 2006 | 06:59 PM
It can be, but you don't have to. There are a couple write-ups in the sticky.
Old Dec 26, 2006 | 07:05 PM
Bigragu,
Wannadiesel did a very nice write up on turning on both filiaments on highbeams like you are suggesting.
Thanks for the help everyone, I did find me some relays. I appreciate it.
Old Dec 26, 2006 | 07:06 PM
Boatnik's Avatar
I myself have done the big wire relay mod with success. What I did was pull power striaght from the positive post on the battery through 10 gauge wire through relays to the lights. I use the original wire harness to energize the relays. One for low and the other for high. I did this because the wire used by the factory was really to small for the load of the two headlights and created too great of a voltage drop.
Combining both beams while on "High beam" is a different story. One that I have not attempted on the Dodge because of the dimmer switch being on the column. On the Ford, or any truck using the floor switch, I just shorted the power side of the switch with the switched leg of the low beam. This way the low beam stays on as long as the head light switch is on. If I can find the factory headlight relay, I will most likely do the same thing at the relay.
Old Dec 26, 2006 | 07:26 PM
BC847's Avatar
1st Generation Admin
Combining both beams while on "High beam" is a different story. . .. .
Boatnik, if you've a separate relay for the high and low bulbs, just take a simple diode and connect it so the 12v power from the column where it connects to the high beam relay, backfeeds the low beam relay. That way, the high beam feed actually powers both relays.
Old Dec 26, 2006 | 08:02 PM
See, I'm to dumb to figure that sort of thing out. I just used a third relay triggered by the high beam wire to turn on the low beam filament.
Old Dec 26, 2006 | 08:38 PM
91.5CTDBanks's Avatar
I got by using 22 amp relays. Work well so far. And inaddition, the smaller red/black stripe wire coming from the drivers side high beam plug is the high beam indicator wire for the dash light. I did not hook mine up at first and the high beam dummy light in the dash did not work.
Old Dec 27, 2006 | 06:00 AM
Jim Lane's Avatar
Originally Posted by IraPatterson
Hey Everyone,
Thanks!
Try to purchase Genuine Bosch if possible; there really is a difference inside.
If you decide on the generics it would be a good idea to get a few for spares and keep them in your glove box. When these go out, it will always be on a weekend or when you are on a dark lonely road.
(Quote)
I have installed mine using 4 relays with one relay for each filament.
I did this so I can have my alarm flash my headlamps in a wig/wag fashion.
Jim
Old Dec 27, 2006 | 07:11 AM
JD730's Avatar
Thats the way I did it on my brothers 96 when his headlamp switch went up in smoke.
Clampett
Jul 1, 2014 11:42 AM
JDGnut
Jan 5, 2008 05:44 PM
4RnrRick
Jan 8, 2007 12:27 AM
Mexstan
Mar 18, 2006 01:27 AM
