air conditioner
Old Aug 20, 2008 | 06:48 PM
sodbuster's Avatar
air conditioner
Ihave 1990 w250 and the air conditioner has stoped the clutch is not kicking in it worked perfect up until a week ago already checked the fuse
Old Aug 20, 2008 | 07:59 PM
wheelo90's Avatar
I would try checking the voltage on the wires that go to the clutch. I have never played with AC much, but I suppose it may be a good start.
Old Aug 20, 2008 | 08:02 PM
Tron's Avatar
Check at the cycling switch. I believe its near the were the a/c lines go into the heater box.
Old Aug 20, 2008 | 09:25 PM
ez_lle71's Avatar
+ 1 on the cycling switch. Mine worked intermittiently for a year and a half until alittle reading on it here on dtr, i bypassed it and now have a AC that blows 28 degrees out of the vents!! Thanks DTR!
ez
Old Aug 20, 2008 | 09:29 PM
93flatbed's Avatar
Is there any r12(or 134a if you made that mistake) in it?
Old Aug 20, 2008 | 09:36 PM
jesussaves's Avatar
your refrigerant might just finnaly leaked out. if you need more you can use this instead of r12
http://hc12ausa.com/
Old Aug 21, 2008 | 03:49 AM
Jim Lane's Avatar
Wow..
That stuff sounds too good to be true.
Quote:
made of natural, organic compounds, not a blend of pre-existing, chemically based synthetic refrigerants,
Has anyone here used this substitute and what were the results compared to R-12?
I would like to try some and compare it but it seens odd that there is only a few places to get it in the USA and it is mail order?
Jim
http://www.hcrefrigerant.com/index.htm
Old Aug 21, 2008 | 07:05 AM
samiam4's Avatar
If you've got a leak- fix it!!
To do a crude recovery, get an empty R12 or 22 30 # container. There's a lock ring around the valve-cut it off. All disposable containers have a 1-way valve. I simply backed the valve out as much as possible, and super glued the check valve piece to the end.
Put the container in a 5 gallon bucket and ice it down heavily. Cold will have most of the freon condense in the container.
M
Santaclaus
Mar 19, 2011 06:06 AM
Copenhagenjunkie
Mar 19, 2004 11:59 AM
chiefneon
Jul 7, 2003 09:15 PM
