93 problems
Old Sep 6, 2005 | 10:40 PM
dodgeman01's Avatar
93 problems
My 93 Dodge will not turn off. when I shut the key off the engine drops a few rpms but does not turn all the way off. I have to put it in gear (auto) and bump the throttle to get it to die. any ideas guys?
DM01
Old Sep 6, 2005 | 10:46 PM
stillsmokin's Avatar
sounds alot like a bad engine stop solenoid. Diesel engines won't run without a fuel source, this solenoid turns fuel off and on inside the pump.
Old Sep 6, 2005 | 11:05 PM
goodtyms's Avatar
Yep, you either spend the big dollars for a new solenoid, or join the cable shut-off club by installing a manual choke cable to the shut off lever on the VE pump.
Old Sep 6, 2005 | 11:35 PM
timb's Avatar
Oh ya, It's your shut-off solenoid all right. have you done any pump mod's lately. you can spend the money in one of two way's. buy the shut-off cable now, or buy a new solenoid and then buy the cable in a couple of day's anyhow. welcome to the club.
Old Sep 6, 2005 | 11:43 PM
Unknown to most there is a extra lever on the VE pump, there is pretty much nothing hooked to it. Moving it to it's stop shuts off the engine.
Old Sep 7, 2005 | 01:28 AM
frostie's Avatar
Hey Dodgeman, long time no see. Yep they are right, If you have pump mods than you will keep replacing solenoids. I would say a shut down pull cable will be your best hope. Piers sold me a solenoid but didnt cut it. Dont be a stranger
Old Sep 7, 2005 | 04:10 PM
mopar2ya's Avatar
Over a million miles and never had a problem with the shut down solenoid, just a wire ocatioanlly comming off and the truck dieing. Guess Im the lucky one...
Old Sep 7, 2005 | 10:41 PM
dodgeman01's Avatar
Yeah its been a while. I have been spending a lot of time on my 94 Dodge this year. got many new goodies like a o-ringed and ported head along with a 215 pump My 93 also has a problem with the right turn signal. the indicator light blinks bright once and then stays on very dim. This is the first problems I have ever had with the truck and its getting ready for the big 200k mark.
DM01
Old Sep 8, 2005 | 01:41 AM
frostie's Avatar
Check both front and rear bulbs. I have seen where a filiment will break and crossover to running light circuit and cause that problem. If both front and rear turnsignal bulbs are OK than I will have to rethink
Cool on the head O-ring, I am porting and polishing my own head right now. I need to find someone to oring it. I dont want to pay $300 for shipping when I may get it done localy for $300
Old Sep 10, 2005 | 03:40 AM
Bluebird's Avatar
Wink 1 million mile plus...
Hey Mopar2ya, can you start a new tread and tell us what you have done to your rig in a million miles plus . I would sure like mine to make it that far Patrick.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
