92 Kdp
Old Dec 8, 2009 | 05:29 PM
Rott-n-dawg's Avatar
92 Kdp
OK feeling kinda dumb on this one pulled apart crank case cover and did the KDP, checked case bolts and got interupted in the project for a while and forgot were the long bolt with the spacer attached goes can anyone help
Old Dec 8, 2009 | 07:05 PM
TIMMY22's Avatar
Should be right over crank. Crank speed sensor mounts too it.
Old Dec 8, 2009 | 07:08 PM
TIMMY22's Avatar
Old Dec 8, 2009 | 07:51 PM
Thank You
A picture is worth a thousand words. Wish I would have done the cardboard trick. I'm not seeing the bolt I'm looking for. I left the bolts for the crank sensor in the bracket. I will have to take a photo of the bolt so that all can see.
Old Dec 8, 2009 | 07:55 PM
The one you are talking about goes right by the damper on the driver's side. It keeps you from putting the belt on - I mean, it keeps the belt from flying off.
Old Dec 8, 2009 | 08:01 PM
here it is
Old Dec 8, 2009 | 08:03 PM
Yup, that's the one I thought you meant.
Old Dec 8, 2009 | 08:08 PM
TIMMY22's Avatar
Bottom row on my pic, just right of center?
Old Dec 8, 2009 | 08:11 PM
So would that be the last long bolt hole on the driver side of the dampner?
Thank you both for the help.
Old Dec 8, 2009 | 08:12 PM
Gotcha
Old Dec 8, 2009 | 08:13 PM
Yeah, looks like it should be the second hole to the driver's side of the crank. The damper should just barely miss it.
Old Dec 8, 2009 | 08:15 PM
First time on a diesel. It has been a learning curve but all should go well from this point forward as when I have hit a road block. Instead of throwing wrenches I have spent time prep work to go back together.
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
