KDP and Oil Leak
Old Mar 19, 2003 | 12:20 PM
WalkingHorse77's Avatar
KDP and Oil Leak
If you have an oil leak at the timing cover does that mean the gear housing definately cracked? Or does it just mean the KDP is loose and needs repaired? Has anyone every tried to replace the gear housing by welding or any other means? Thank you for help ! <br><br>Adam
Old Mar 19, 2003 | 12:27 PM
Paul Winey's Avatar
Re:KDP and Oil Leak
Doesn't necessarily mean either. Mine had a leak from the timing cover gasket and seal. Bolts on cover were not up to torque when I bought the truck. Tabbed the KDP (hadn't moved), new gasket and seal and it hasn't seeped since. Took some time but well worth it. Check out the tab repair instructions and it will tell you where you need to look to usually find a crack. Worth the time to tear it all apart and know for sure!<br>
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
dieselpwr15
Jul 22, 2008 05:49 AM
stroker4501
Oct 30, 2007 02:22 PM
Burrito
Apr 13, 2006 11:51 AM
