92 12 valve
Old Oct 9, 2014 | 11:23 PM
apprentice's Avatar
92 12 valve
I took my 205 tcase out and did some tranny mods, It's been 2 years and i cant remember the stock clock position can some one take a photo from behind looking at the t case please?
Old Oct 10, 2014 | 12:18 AM
Here's mine on the crewcab...
Old Oct 10, 2014 | 01:23 AM
apprentice's Avatar
thanks looks clean flush with the bottom or the trans cross brace nice!
Also a few bolts are corroded anyone think it is possible to source the trans to transfer case stud style bolts new all 8 ? my dealer cant be bothered to look it up. I called twice they don t call back.
Old Oct 10, 2014 | 01:25 AM
apprentice's Avatar
Wonder if its the same on the auto?
Old Oct 10, 2014 | 08:07 AM
The T-cases are not the same on the inside, auto to manual, but they are in the same location on the truck.
From the outside they look basically the same.
Old Oct 10, 2014 | 11:30 AM
Here is the same TC when it was hooked to the A518 in my donor 93 truck.
BTW I converted the 23 spline auto NP205 to the bigger 29 spline so I could run it behind my NV4500.
Old Oct 10, 2014 | 06:29 PM
apprentice's Avatar
many thanks ... now the 8 corroded studs from trans to t case is there a part number for those sorry my dealer wont get back to me.
Old Oct 10, 2014 | 07:01 PM
Mine only has 6 studs. See if you can wrestle one out, and see if you can get something through a local Fastener supplier, or maybe on-line through Mc Master-Carr?
Or you could look for another tranny to transfer case adapter?
Old Oct 24, 2014 | 06:06 PM
apprentice's Avatar
Part numbers for stud and nut are oem dodge 04505365 stud, 06033172 nut. Again thanks.
Old Oct 24, 2014 | 06:13 PM
maybe368's Avatar
The size of the stud is M10x1.54x36, readily available...Mark
CajunDiesel
May 23, 2004 08:49 AM
piperca
33
May 11, 2004 06:40 PM
skinsey
Jul 17, 2003 05:47 PM
1320
May 17, 2003 03:28 PM
phildog
Apr 2, 2003 05:44 AM
