90 Is A Dog
Old Jan 9, 2005 | 01:55 AM
rebal's Avatar
Question 90 Is A Dog
WHY IS MY TRUCK ACKTING LIKE A DOG , heres what i have done to it .3.5"exhaust strait pipe, k&n and modifided air cleaner , htt h1c 16mm hybrid turbo 35 psi boost afc disabled cone turned to let pin out farther, pump turned 1.75 turns, custom intake (4"smooth pipe to turbo) 2.5 " to 3 " cross over to air inlet in head and pre heater removed valves adjusted .fuel filter change ..? the truck starts real good but i think my injectors are not up to snuff from what info i got earlyer will that make for low power too? and could the auto trans have some affect in this. or am i just missing something? oh ya i have no intercooler but am looking for one .anyone have some ideas
Old Jan 9, 2005 | 04:03 AM
frostie's Avatar
Does your truck smoke? if so is it black or white?
It seems the air system, meaning intake and exhaust is good, now I wonder about your fuel system. 35 PSI boost seems good.
If your nozzles are old they may not be atomizing the fuel good, You can have them tested or just put a set of PODs in
Need more info.
Old Jan 9, 2005 | 10:57 AM
rebal's Avatar
it smokes really good from a dead stop (looks like an east german coal fired power plant) and has a lot of gray at hiway speed and wot.
Old Jan 9, 2005 | 01:03 PM
uncleroty's Avatar
Yeah, I'd look at the injectors as well. You can have all of the intake and exhaust in the world, but if you can't get enough fuel in, it doesn't matter.
I guess you get extra smoke etc when you turn up the pump anyways, so I Don't know if that's an indicator of anything.
You sound like a performance guy, so I'd not even worry about the old ones, just do the POD's. Have fun with it!!
Old Jan 9, 2005 | 05:52 PM
rebal's Avatar
pod where to buy?
Old Jan 9, 2005 | 05:54 PM
PDR or Ebay.
Old Jan 9, 2005 | 06:00 PM
rebal's Avatar
thanks
Old Jan 9, 2005 | 07:15 PM
sammy340's Avatar
Rebal
Can you post a pic of your turbo setup. I wont to send my H1C to HTT and get the stage 3 upgrade but from what i've heard you need to do some different plumbing to get the compressor outlet to match up to stock piping on a non-intercooled truck. Do they give you a whole new compressor housing as well as wheel?
thanks
Jeff
Old Jan 9, 2005 | 10:16 PM
ctd89-99's Avatar
Rebal, Check to make sure your throttle in opening the whole way, the cable gets strecthed and you wont get full travel. Thanks Steve B.
Old Jan 10, 2005 | 11:22 AM
Redleg's Avatar
Throttle cable and pedal travel too. Make sure you don't have lot's of room left before the pedal hits the floor. Run a strong dose of injector cleaner too. Crack your injectors one at a time with the engine running. See if the idle picks up at all immediately after and tapers back off. Before I did my fuel lines, I think I was getting just a touch of air in the lines (but not enuff to stall). A couple times I had to crack the injectors, the idle seemed to smooth out and pick up slightly. Didn't think much of it at the time, but later lines started leaking at the tank and got replaced.
Old Jan 10, 2005 | 11:38 AM
jleonard's Avatar
I'd like to see a pic as well.
Thanks.
Jay
jay.leonard@timken.com
Old Jan 10, 2005 | 09:42 PM
rebal's Avatar
pictures are in my ]
Old Jan 11, 2005 | 03:33 AM
frostie's Avatar
If you send your turbo to HTT they will machine your housing so it will bolt right back up, no housing swap.
good luck
blk dually
Oct 23, 2004 04:21 PM
chevkiller
16
Feb 16, 2004 01:14 PM
NWDave
Mar 13, 2003 05:58 PM
Push Rod
Feb 8, 2003 07:51 PM
