auto trans fluid & filter change
Old Jan 9, 2005 | 06:03 AM
boiler-rat's Avatar
I'm gonna change the AT fluid and filter today IF the local parts store has the filter. Anyone have any suggestions, do's , dont's or upgrades before I start?
Old Jan 9, 2005 | 09:13 AM
dzpoorjr's Avatar
Yeah-put in 2 qts of 30 wt oil to keep the temps down and add a bottle of the Lubegard! IT ALL HELPS! You will get firmer shifts and less slipage! Do you have a drain plug in pan? If not this is the time to put 1 in!
Old Jan 9, 2005 | 12:55 PM
Andyinchville's Avatar
I'm not sure about using the motor oil part but I have heard that some people run the F trans fluid forquicker shifts....I run Type F in all our company's trucks.
Old Jan 10, 2005 | 01:48 AM
rebal's Avatar
my truck has 250K + on the stock 727 and i have put the amsoil atf in it since 25K and the trans is still going and the pump has been turned up and i tow a 10K trailer a whole lot .I think thats why im just now needing to get the trans in for a refresher ...its still going just feels diff latety
Old Jan 10, 2005 | 08:17 AM
Nuttymopar's Avatar
Adjust your Tranny bands while having the pan off. I don't have my manual right in front of me but I think one is inside the pan to adjust. Torque it ot 72 INCH pounds and then back off (I think) about 2 turns. Don't quote me as I haven't looked in the manual for some time about this.
The other adjustment is outside the pan and it is torque to 72 INCH pounds also and then back off 2 turns I think.
Old Jan 10, 2005 | 07:49 PM
boiler-rat's Avatar
Thanks for the replies. I ended up using a Mobile1 oil filter and just changed the trans fluid and filter. I used Castrol ATF. The air filter was dirtier than what I wanted so I put an STP from Autozone on. I am getting the material gathered to build an Old Smokey mount but I didn't wanna wait till then to change the filter. Also gonna wait until I get a service manual before I adjust the bands. The magnet in the pan had a little powder fine particles on it. There was also a few specks of aluminum in the bottom of the pan. How bad is that? Gonna do the diff and transfer case oil change next week-end weather permitting.
Old Jan 11, 2005 | 06:59 AM
Nuttymopar's Avatar
Little specks sounds like normal wear. I have seen think goop in mine but that was the original tranny and not sure of the maintence record before I got it. Since replacing tranny, I see little specks now and then doing maintence on a regular basis.
1stgen1993
Dec 8, 2011 08:46 PM
jj3500
Jul 4, 2008 07:11 PM
snowmanx
Oct 23, 2006 05:38 PM
Pooter
Oct 4, 2006 12:26 PM
icrider
Sep 27, 2006 03:10 PM
