89 cummins,fuel in the oil pan?
Old Mar 29, 2007 | 07:13 PM
6006spd's Avatar
looking at buyinga 89 3500 cummins,has 136k on it. mint shape one owner.runs great but he says it is getting fuel in the oil. what do u think the prob is? smokin deal,dont want to miss but dont what a big problame either. any help/advice? thanks guys
Old Mar 29, 2007 | 07:20 PM
odin1954's Avatar
I would look to the injection pump when they leak it gets in the oil
Old Mar 29, 2007 | 07:30 PM
6006spd's Avatar
odin. do you think the pump needs rebuilt? or a seal or sumthing simple?
Old Mar 29, 2007 | 07:36 PM
odin1954's Avatar
I,d go for a rebuild
Old Mar 29, 2007 | 07:39 PM
gman07's Avatar
It could a bad lift pump leaking fuel into the oil or it could be the seal at the front of the injection pump leaking. If you look online you can find the lift pump for ~$50.
The injection pump seal requires pulling the pump (I've never done it, but I don't think it would be too hard) to replace. My injection pump went at about 170,000 miles, but many seem to last far longer than that.
Old Mar 29, 2007 | 07:50 PM
jdwest's Avatar
I second the lift pump idea. When the diaphragm goes bad/tears it will cause the pump to leak fuel into the crank case. That's what mine did...started making oil. New LP is like $80 from Napa...and that's on the high side. They can be found cheaper.
Old Mar 29, 2007 | 09:26 PM
ihpower's Avatar
i had this problem with my truck and the front seal of he injection pump went out. Pull the pump replace the seal pump put pump bakc on. i took it to a pump shop and the charged me 20 bucks to do,with me pullin the pump,it and it toook about 5-10 mins. BUt i have also heard ip the lift pump doing the same thing.
Old Mar 30, 2007 | 07:19 AM
6006spd's Avatar
thanks for the help guys,anything else i sould keep an eye out 4 on this thing? going to get it and try the lift pump first.
Old Mar 30, 2007 | 01:41 PM
dpuckett's Avatar
Just the normal 1stGen stuff that you would expect to possibly go wrong in a 18year old truck- front end, lights/ electrical, body.
Daniel
Old Mar 30, 2007 | 07:52 PM
6006spd's Avatar
Thanx 4 All The Advice Guys Its Been Great!
04ctd
Apr 21, 2008 03:16 PM
EverydayDiesel
Nov 11, 2007 09:33 AM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
