5th gear weirdness
Old May 22, 2008 | 04:00 PM
93namedchester's Avatar
5th gear weirdness
shifting my getrag out of 5th gear is a real unnatural motion. I have to 'pull' it out of gear in a clockwise half circle motion (if not done correctly it will jam in 5th even though the shifter is in the nuetral position). I'm no mechanic and know nothing of transmissions. Is this normal for a getrag or are the shift patterns just worn out?
Old May 22, 2008 | 04:21 PM
apwatson50's Avatar
yeah sounds like the shift tower (the top part of the transmission that has the shift rails and holds the shift forks) is worn.
Old May 22, 2008 | 05:05 PM
thanks man. is that an expensive problem?
Old May 23, 2008 | 09:12 AM
apwatson50's Avatar
The most expensive part would be the labor to remove the transmission to actually remove the shift tower cover. Or you could cut the floor board out and make it removable then you'll be able to remove the cover without removing the transmission.
Also "reman" covers can be purchased for I believe somewhere about 3-4 hundred. Do a search on here and someone found a place that rebuilds them.
Aaron
Old May 23, 2008 | 09:24 AM
thanks Aaron.
Old May 23, 2008 | 10:58 PM
stackx2's Avatar
mine does the exact same thing if you dont shift in a square pattern or cheat it into 4th it gets stuck and wont go back into 5th so you have to jam it back in. i hate it but ya your shifting tower is worn out it not that bad to fix just need to find the parts.
LemonDodge
Sep 7, 2019 03:51 PM
LemonDodge
Sep 16, 2010 07:33 AM
Wilber1
Feb 23, 2008 10:07 PM
v8440
Jan 25, 2006 07:28 AM
mamm7215
Jun 2, 2004 09:22 AM
