50W Synthetic trans oil
Old Jan 26, 2011 | 09:46 AM
Bencie's Avatar
Any thoughts on using this in a high mileage getrag, I'm sure the tolerances are no where near where they were when it was new? This is what Eaton Fuller uses in their modern transmissions.
Old Jan 26, 2011 | 10:34 AM
ppiggppenn's Avatar
My rebuilt Getrag came with a locally produced instruction recommending engine oil with the one quart overfill, and especially to use synthetic. I dumped my initial overfill down the shifter hole and after a few years used a suction gun and pumped the extra quart thru an upper bolt hole on the other side plate (mine's 2WD).
Old Jan 26, 2011 | 10:57 AM
Bencie's Avatar
I'm aware of the recommened oil and overfill, just wanted thoughts of using a slightly heavier single wt. oil in a well used (loose) getrag, pros and cons. Thanks.
Old Jan 26, 2011 | 10:09 PM
Bencie's Avatar
Any thoughts? Will this wear the syncros faster or make the trans run hotter than normal and they already run pretty warm. The third gear syncro is already lazy in my 90 and wondered if 50W syn trans would hurt it further or not.
Old Jan 27, 2011 | 04:10 PM
bgilbert's Avatar
A couple guys on another site have been using 50W synthetic and like it. One of them, Michael Miller, says his getrag temps have been running cooler. At my next change I plan to try some 50W.
Old Jan 27, 2011 | 04:51 PM
Bencie's Avatar
Thank you, I'll give it a try too.
Old Jan 27, 2011 | 08:59 PM
big stinky's Avatar
Im running 15 50 synthetic in mine. 3rd gear is cranky till its warm. Im gonna try throwing a bottle of rp syncromax in there, see if that helps...
Old Jan 28, 2011 | 04:05 PM
Bencie's Avatar
What's this rp syncromax? thanks.
Old Jan 29, 2011 | 12:00 PM
big stinky's Avatar
royal purple
Old Jan 29, 2011 | 08:15 PM
Bencie's Avatar
10 4
Roadstar
Jan 14, 2010 03:50 PM
wrm
13
Feb 14, 2007 05:38 PM
bobbywebb
Oct 29, 2006 09:50 PM
rico334
Jan 3, 2005 08:10 AM
snice
14
Apr 29, 2003 08:41 PM
