synthetic oil back to conventional oil.
Oil is oil. All oils say they are compatible with other oils. If you have concerns contact Blackstone or another oil analysis lab and ask them if there could be any harm in mixing synthetic and dino oils.
Could be an old wives tail, but I heard long ago that it is better not to mix the addative packages of different brands of oil. I always followed the advice, but I haven't done any testing to see if it actually makes a difference.
Switch Yes, Mix No
I posted this awhile back for a similar question:
I used to do analysis of motor oils for Maryland. You can switch from dino to synthetic fine and always replace the filter too. Don't mix synth with dino or even other brands of synth or dino together. It's not the oils themselves, it's the additives. Each batch has a unique mix of additives. The additives may be so different, that they cancel each other out or worse, react and make a sludge.
Otherwise I'd have to call this one BS
Just saying.... If there is a possible reaction I'd like to know it! I think we all would! What if we're 200 miles from anywhere and we need to add 6 quarts of oil and all we can get is brand X, and we are using brand Z. Are there any two oils that when mixed will cause a real problem?
My gut is saying no, but if my gut was always right I'd be a zillionaire!
API-CJ4 Standards
If you take a look at the attached file you'll get an idea of how complex the lube oil standards are for our trucks. Each batch of oil is different and to get a particular batch to pass all the tests, the manufacturers use additives. The problem is that very different additives can be used to get similar results.
Of course, if you're stuck somewhere, you have to take what you can get.
Yes you can mix oil's. You can even buy a synthetic oil, conventional oil blend. I know a guy that has been blending his own oils for 40 years now.
He blends 10 weight with 40 weight. He thinks it will work better than 10x40.
^^ He must be awful confident that he can produce a product better than a lab and a scientific staff dedicated to the task.
IMO most of the advertising is hype. I use dino and synthetic for different applications and have never had an oil related failure ever. I have a small generator that's showing some age but at +3000hrs on a B&S engine, it's earned its RIP .
John Davison
02-20-2014 11:39 AM
6.7megaman
01-29-2010 03:15 PM
Roadstar
01-11-2010 06:44 PM
