400 HORSES WANTED!!! Is this how?
Old Mar 10, 2007 | 06:18 AM
pred's Avatar
I have a NON IC truck to start with.
I would like to acheive this and still be able to tug 10K loads occasionally.
Here is what i think will do it,
A wastegated turbo w/ stage 4 kit
A big ole ferd intercooler
EDMs!!?!?!!!!
I think that i have all the other goodies already on my ride,
OH 1 MORE thing,,,, Walbro fuel system, stock wont cut it.
I have a 5 speed, and would like to have this power to tap occasionally,
Thanks for any imput.
I do alot of highway driving, Sitting near 75-80 alot of the time,
I am not sure about a 12 cm wg, But dont see many options.
I am running a 18 cm with a stage 3, and hitting 42 lbs without the H2O meth, So i need a WG.
Peter.
Old Mar 10, 2007 | 07:08 AM
JD730's Avatar
I'm sure wanna will have something to say about the stage IV and breaking the 400hp mark, but I don't think 400hp is an attainable number with just a hybrid, drop a HT3B underneath it and 400hp wouldn't be a problem with fuel. You would need to step up to a larger turbo like one of the S300 builds.
Old Mar 10, 2007 | 10:24 AM
johnny5.9's Avatar
Don't forget you'll need a clutch to hold that power.
Old Mar 10, 2007 | 01:49 PM
pred's Avatar
What is a HT3B?
what is a S300?
and where can i get a look at these items?
Peter.
Old Mar 10, 2007 | 02:20 PM
65fury's Avatar
Originally Posted by pred
What is a HT3B?
what is a S300?
Peter.
the ht3b is the large turbo used in a twin setup, which runs off the exhaust gasses from your top turbo(can use stock one) the s300 is just a single turbo but moves alot of air and can handle 400hp, check out HTT (high tech turbo)for the ht3b they also have the s400 which is also a bottom turbo in a twin setup (s400 is what im going to use on my twins) hope you make your 400hp goal.
jason
Old Mar 10, 2007 | 03:01 PM
Yep. Gonna need a real turbo (or twins) to make that kind of power.
Old Mar 10, 2007 | 03:25 PM
Fergavs's Avatar
Do you want 400hp with the W/M or all the time PLUS the W/M? I am running the S300 from BD Power(see sig) and am very happy with it. It has an extended tip comp wheel. I believe it is only a 57mm wheel so it spools like a small turbo but because of ther extended tips it moves air like a larger turbo. Also the super B I use has a 14cm W/G turbine section. Spools very quick plus no restriction on the top end. I have not been on the dyno yet but I think I am close to 400hp with out the W/M and over 400hp with. Just guessing right now however. Also I will be doing twins as the budget allows and will do either another S300 or the bigger S400 for the bottom turbo.
Old Mar 10, 2007 | 04:22 PM
Fergavs's Avatar
http://www.htturbo.com/htb2.htm
The S300G looks to be exactly what I use. The site rates it up to 425hp.
shortround
Oct 1, 2003 06:43 PM
gadgets
Aug 1, 2003 04:52 PM
cr1998
Dec 23, 2002 10:50 AM
Nov 12, 2002 12:20 AM
