3200 questions
3200 questions
a few problems and questions
1. the diaphram spring appears to be upside down on my truck(red side up)is this bad???
2 I have runaway condition I have installed the throttle shaft as it was then 1 spline cw an 1 ccw of original still no luck.(is it possibe to 180 degrees off?)
3 the small boost line had plasic washer on on the back and one in the front (it was note to be cooper not plastic) is this bad?
4 is it possible when puting top of pump back on the black levers inside are in wrong place??
I guess its possible, but I think its unlikely.
If you haven't already check these links out.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
and this one
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
Do your self a favor and unhook the intake on the head or unhook the aircleaner from the turbo and get your self a board that fits over them so you can shut it down if the shutdown lever doesn't work.
its on the back side of the pump......i don't thing that any of the 3200 spring install pic's show it. at least i didn't see it when i scanned over it.
try this one,
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
the pic shows steel collar,Jambnut
and power adj screw! that's the full power screw!!!
spring
all is good now.
it looks like someone had moved the diaphram to about 5 oclock(previous owner), i move it to 3 oclock and runs like a charm. it feels great, best $19.00 canadian i ever spent.
Ilikebikes
Sep 12, 2006 06:19 PM
