3200 gsk better for towing?
Old Dec 26, 2005 | 11:11 AM
csramsey640's Avatar
I have the 366 spring, and have been wanting to install it. Does it help better with towing? or is it more for "horsing around"
Old Dec 26, 2005 | 11:21 AM
John Faughn's Avatar
From what I've read it helps a lot for towing and horseing around , it spouse to alow fuel at higher RPM so if your running at up RPMs then you may want it ,
Old Dec 26, 2005 | 11:47 AM
flyingd's Avatar
I have installed the 32K spring and I tow a lot during the summer .
It helps when going up a grade. I have an automatic and when I drop out of OD I can still maintain speed up the grade. I like it. You will too
Old Dec 26, 2005 | 01:18 PM
G1625S's Avatar
Put the spring in, you will not regret it! This is the one mod that has absolutely no down side. It is especially nice when towing with the getrag, as the extra rmp keeps you from having to bog it on the 2-3 (and the 3-4) shift while getting up to speed. Wind it right up in 2nd and you land right in the sweet spot in 3rd, rather than 1300 rpms---a big plus, in my book.
Old Dec 26, 2005 | 01:19 PM
What flyingd and Greg said.
It really helps with that giant hole between 2nd and 3rd on the Getrag, and it's also nice to have good pulling power at 70 in direct drive. Being able to pull at highway speed in direct drive takes a lot of load off the engine and trans, which helps keep everything cooler.
Old Dec 27, 2005 | 07:15 AM
Boatnik's Avatar
Read my sig.....I love it.
rebal
May 4, 2006 09:31 AM
ViperSBT
Dec 6, 2005 10:42 AM
csramsey640
Sep 12, 2005 03:31 PM
PapeCAT
Mar 20, 2005 10:44 AM
bigred496
May 28, 2004 12:36 AM
