300hp and 750tq?
Old Aug 22, 2006 | 12:55 AM
red_neck1984's Avatar
Cool 300hp and 750tq?
Take a look at this http://www.jannettyracing.com/pkg.sh...odge%20Cummins
Thats some good numbers would that be good for towing?or just play?
Old Aug 22, 2006 | 01:09 AM
Ilikebikes's Avatar
I wonder how much that kit costs? Honestly, I don't see the need for a "custom 3000 RPM pump" when you can put a $20 spring in there for 3200 RPM. Also, a 12cm wastegated housing can be had for $75 or so.
Old Aug 22, 2006 | 01:17 AM
Ace's Avatar
Ace
Definitely more hype than substace there, IMHO.
Old Aug 22, 2006 | 02:08 AM
PapeCAT's Avatar
kind of takes away the hype when it tells you exactly what you are getting. a little bit more air and fuel and some fancy clutch or auto trans gizmos to put the power to the ground lol
Old Aug 22, 2006 | 02:44 AM
frostie's Avatar
Interesting,
You can buy PODs for about $400 An old smokey power pin for about $250, and a good turbo for about $900.
For $1550 plus a bit of your own labor,
I dyoed 332HP and 794 LB FT of torque.
If you buy the HX 35 used, you can cut $500 plus out of the price.
Old Aug 23, 2006 | 12:19 AM
Lol
Its all numbers on the net i would like to see it on some dyno
Old Aug 23, 2006 | 06:07 AM
JD730's Avatar
Here's one of my previous dyno runs. Before and after 3200 gov spring. Still had a stock turbo with 16cm housing. Torque curve looks funny on the one because the turbo wasn't spooled or the trans was slipping, not sure which. Torque should have peaked around 730 ft-lbs.
I've upgraded the turbo since then and I've turned the full power screw in alittle more, which has more room to go. Haven't dynoed yet, but it should be around 300/750.
Old Aug 23, 2006 | 11:25 AM
TexasHardcore's Avatar
On my old '92 D-250...
4"x10' Exhaust Tubing - $30
4" Flexible Exhaust Tubing - $10
5"x4' Exhaust Tubing - $10
Used the flared stock tailpipe as a reducer from the 4" to the downpipe. $0
Fleetguard BHAF - $20
Homemade Alum Heat Deflector/Air Box - $10
Junkyard HX35/12cm2 Turbo - $100
Welded Wastegate Shut - $0
Holset HX35 Turbo Rebuild Kit - $40
Holset HX40 Compressor Wheel - $40
Custom Machine Work on Turbo - $0 (at work)
Lucas POD Injectors - $150 (used from "NeedMoPower")
Bosch 3200 Gov Spring - $17
Pump Tweaking - $0
DDP Old Smokey Fuel Pin - $200
Southbend Con O Clutch - $475 (after stock clutch gave out at 147k)
Autometer Pro-Comp Boost & EGT Gauges - $90
HVF Cool-Down Timer - $75
$1,267 for all mods made 341hp/841lbft at 46psi. Got 24mpg on the highway, 19mpg pulling 10k.
Old Aug 23, 2006 | 12:45 PM
jrussell's Avatar
How old are those prices exactly?
$6.60 per foot for 3.5" = $66+ for 4" Link
$5 per foot = $20 for 4' Link
5' for $55 Link
Sweet trick!
$30 + $10 shipping Link
Pics?
$30 with shipping from Pier's, but it should be only $17
Pump Tweaking - $0
Gotta love the free HP!
$105 for Pyro and $52 for Boost = $157 Pyro Link Boost Link
$100 shipped Link
With today's prices you're well above $1,267. Sorry, but I'm gonna have to call bs on your mpg figures. Only way you got 19mpg towing 10k is downhill with a tailwind.
Old Aug 23, 2006 | 02:15 PM
Everything was bought locally or off eBay.
Exhaust stuff was from a local muffler shop where they gave me a "bro deal".
The filter was from a local big truck shop in Waco, TX. I still have the reciept at $19.91.
Turbocharger stuff was done by me when I worked for a turbocharger shop.
The air deflector was made from a sheet of alum that I bent over at the top, TIG welded in a flange for the stock inlet tube to fit over and bolted into the stock locations. I'd have to go through old CD's to find any pics.
Governor Spring was from another local Bosch/Cummins dealer in Waco, TX.
Gauges off eBay as a package deal for jap cars, new in boxes.
Cool down timer direct from Howard Van Fleet for $75 shipped.
I'm sure prices have changed since I did this truck. I sold it around August of '05 or somewhere around there (still kickin myself for doing that) I bought the truck in 'December '03.
I'm only saying how I did my truck, and what the results were. I hope others can use this as a helpful tip that you dont have to dump loads of cash into these 1st Gens to make reliable power. I never saw EGT's over 900* (post turbo) daily driving/highway/hot rodding...
I was impressed with this truck and what little was done to it to make that kind of power. I couldnt have done it without the help from Cody (aka NeedMoPower) the DTR, and the Waco Diesel freaks making fun of me for making no horsepower the first time we did a dyno day when my truck was stock. Most people can't do this stuff on their own, so spending money is all they can do...luckily for me, I have the tools & ability to do the work myself...which really helps save money and adds alot of pride to the results. I was broke when I did that truck...I shouldnt have spent any money on it, but I can't leave anything alone.
As for the mileage...24mpg from Waco to Kansas City, MO empty, and 19mpg pulling around 10k on the way back to Waco. Maybe my speedo was off, but thats what the calculator said.
Old Aug 23, 2006 | 02:21 PM
thats some good numbers your putting up .if i could do that i would be set .So towing egts dont go up to bad?jd730?
Old Aug 23, 2006 | 02:48 PM
JD730's Avatar
The egts during those dyno runs ran right up around 1500*. If you kept the boost below 25lbs and didn't lug it egt's where ok and would run around 1000 to 1100 pre-turbo.
I've since then upgraded the compressor to a HTT stage IV and I'm running a 12cm wastegated housing due to my tight torque converter, turbo lag and smoke where terrible. Egt's dropped 100 to 200* towing the same loads.
jpz67
Jan 1, 2007 09:20 PM
streetsmoker
Feb 24, 2006 03:15 PM
wtmtnterror
Apr 14, 2005 03:01 PM
hertz
Feb 4, 2005 07:27 AM
pmtg
Feb 18, 2004 01:08 PM
