2x4 front brakes
Old Oct 20, 2005 | 08:24 PM
keithplacervill's Avatar
Question 2x4 front brakes
my father has a 93 2x4 5 speed stand cab 3/4 truck and i know on mine i have a special socket i was wondering if he had some thing like that to take off the front rotors or what does it take
Old Oct 20, 2005 | 09:11 PM
12valve@heart's Avatar
It's been a while since I was into the front of mine but I think I just used a channel-lock pliers on the front spindle nut (or a large socket, not special, just large) like any other 2wd vehicle. You will have to pull the calipers to get the rotors off but I don't recall anything special there either. Hope that my menory is correct. I'm sure someone else will chime in if I'm wrong.
Old Oct 21, 2005 | 07:00 AM
csramsey640's Avatar
yeah they shouldnt be tight, if its really tight, better get some bearings and races while your at it. Should be easy
Old Oct 21, 2005 | 10:17 AM
Micaiahfied's Avatar
you have to remover the brake line to get the caliper off as well. but since you are in there you should change the rubber lines anyways.
Old Oct 21, 2005 | 10:24 AM
Dan Brooks's Avatar
12valve - You're memory is correct. The front is just like any older rear wheel drive vehicle...just bigger. I use a big crescent wrench instead of channel locks - gives a better "feel" when tightening the bearings.
You don't need to remove the brake line just to pull the calipier off the mount, only if you're replacing the caliper and/or hose. Just don't let the caliper hang by the hose....
Old Oct 21, 2005 | 10:29 AM
when i did mine the bolts would not clear each other... i had to take the line off.
Old Oct 21, 2005 | 10:36 AM
Dan Brooks's Avatar
You must have different calipers than mine. My calipers have two bolts with flat spring-type retainers that bolt on from the outer edge. Maybe you pulled the caliper mounting bracket off the spindle?
Old Oct 21, 2005 | 10:50 AM
Dan Brooks's Avatar
Here is a pic from the FSM showing how my calipers bolt on:
Ranchhand Ram
Jul 21, 2013 09:22 AM
PeytonMaterne
Aug 27, 2012 08:33 PM
'91 VE
Feb 20, 2009 08:03 PM
wildcargo
Nov 29, 2005 04:20 AM
Pwr Generation
Nov 21, 2005 08:59 PM
