2nd Injection Pump still no luck
Old Mar 14, 2015 | 07:40 PM
SmokeScrew's Avatar
1990 3/4 non IC truck
Injection pump went out a little while back. I rebuilt it myself with a kit from Bosch but the pump never functioned correctly. It never had any power.
I bought an IP from Pensacola Diesel. But the truck runs rough at idle now. The truck violently shakes and misses. If I hit the pedal a little bit it runs smooth. Could something be off in the IP internals?
I got 300k+ on the truck. Had an injector job done about 4 years ago. Is it possible that a IP functioning correctly is revealing a stuck injector that wasn't stuck with the incorrectly functioning IP?
Old Mar 14, 2015 | 09:05 PM
How low is your idle? If the truck smooths out when you bring up the throttle, maybe it just idling too low?
Old Mar 14, 2015 | 10:01 PM
SmokeScrew's Avatar
The idle speed is great. The speed seems right. It was set Pensacola Diesel. I also have two other running VE pump trucks to compare the idle to. I'm very positive the idle speed is not the issue.
Could it be a stuck valve in the back of the pump?
Old Mar 15, 2015 | 02:56 AM
Jim Lane's Avatar
Are you sure the injector lines were connected correctly?
Can you borrow a compression tester?
Have the valves ever been adjusted ?
Old Mar 15, 2015 | 07:26 AM
I had the exact same symptoms when my throttle lever indexing was one spline off. I re-indexed it, and it's run beautifully ever since.
Old Mar 15, 2015 | 11:35 AM
bobva's Avatar
Thats whats wrong with it.
they got a bad reputation.
Old Mar 15, 2015 | 12:53 PM
SmokeScrew's Avatar
I have owned the truck for a decade. I know the compression is good. I adjust the valves every couple years. I am very confident the valvetrain is good.
I am really stuck here because when I put the old pump on (the one with no power) it does not miss at idle. I am taking off the new pump right now and putting the old (no power) pump back on. I'll see if the miss goes away again.
Old Mar 15, 2015 | 12:55 PM
SmokeScrew's Avatar
That is where I started when this problem began. I re-indexed it, but that doesn't seem to be the problem. If I take it off the spline it's on, it will run away. It doesn't seem to be a spline related issue. I can't see where the spline would be off on Pensacola's pump out of the box.
Old Mar 15, 2015 | 01:28 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Wouldn't surprise me in the least...Pensacola has a TERRIBLE reputation because of selling junk pumps.
Old Mar 16, 2015 | 10:21 AM
Angry Johnny's Avatar
Well, if it doesn't do it with the old pump but does it with the new pump I think you've found the problem.
babyray55
Jul 2, 2011 02:43 PM
Homestead
ABDTR #5
19
Jan 31, 2009 11:52 AM
ratlratl
Nov 9, 2008 10:37 PM
Dodgezilla
47
Feb 22, 2008 10:02 AM
cameroneod
16
Oct 5, 2007 12:36 PM
