2nd gen injectors
Old Sep 1, 2008 | 08:09 PM
ol' 93 12 valve's Avatar
2nd gen injectors
Can i run a set of aftermarket 2nd gen injectors in my 1st gen?
Old Sep 1, 2008 | 08:15 PM
Philip's Avatar
No not without some rework.
The fuel line fitting is different thread. The pop pressure on the injectors is higher for a P-Pump. The spray angle is different on the second gen injectors.
Old Sep 1, 2008 | 10:13 PM
93Fury's Avatar
So how are people running injectors like New Era 435's and such in these trucks? Custom lines? I doesn't specify on their web site whether or not it for a 1st or 2nd gen. Not calling you a liar or anything, just curious. There is a guy I've seen with a track truck ('92 2wd 3/4 ton) and he said he is running 435's in it. Said he bought them for is tow rig which is a '96 3500. Said he ended up putting 370's in that truck though. Is he full of crap?
Old Sep 1, 2008 | 10:31 PM
CaptainChrysler's Avatar
You have to put the 2nd gen nozzles into the 1st gen bodies. P pumps use larger threads for the inj. line. 14mm vs. 12mm for a VE, I believe. Pop pressure has to be reset as well.
Ezra's Avatar
New Era makes 435's and 370's for 1st gens.
Old Sep 1, 2008 | 11:13 PM
93Fury's Avatar
Yeah I found them. Thanks for the help.
Old Sep 2, 2008 | 07:27 AM
C/PRD/'s Avatar
He may have swapped the nozzles and the pintle out and used the 1stgen bodies. It can be done in a vice in a few minutes.
Old Sep 2, 2008 | 03:38 PM
bgilbert's Avatar
Only they don't seem to be making any HP in 1st gens.
prozach007
Sep 27, 2010 08:57 PM
hipsi
Mar 17, 2008 12:10 PM
59FORD
Aug 7, 2005 10:15 AM
RedRotors
Jun 22, 2005 07:12 PM
