2 instead of 1
Old Aug 5, 2008 | 09:05 PM
Big Red 97''s Avatar
2 instead of 1
How would i go about making the rear end in my 93' a posi-trac so i get both wheels pullin at once? Is there a simple kit that i could buy or what?
Old Aug 5, 2008 | 09:21 PM
mullishacrew's Avatar
i thought they already came with the posi, the clutchs might be gone inside
Old Aug 5, 2008 | 09:49 PM
RumbleFish's Avatar
Old Aug 5, 2008 | 10:30 PM
C/PRD/'s Avatar
X2X2X2X2X2 Weld that sucker! It will hold great, but sucks big time on wet pavement when you're in a hurry.
Old Aug 5, 2008 | 10:52 PM
Montana2x2's Avatar
Find a d70 with posi and either swap the rearend or put the posi in your housing.
Old Aug 6, 2008 | 04:50 PM
Your power lock could just be wore out. I thought my truck had an open diff until I pulled the cover. Check the equipment sticker under the hood (if it's still there) or pull the cover and have a look. Could be as easy as new clutches.
Old Aug 6, 2008 | 06:45 PM
Richie O's Avatar
366 Spring Chicken
both my 89's had open diff. My 93 has a ls and now so does my 89.
Old Aug 7, 2008 | 01:41 PM
I looked at the equipment identification sticker. It is faded badly but i could make out what it said. It says limited slip so i will need to do something to make it posi-trac. And also i was trying to determine what the rear end ratio was. I can make out 3:5 and i believe the last number is 4. Is that correct? is a 3:54 one of the ratios they used in the 1st gen trucks?
Old Aug 7, 2008 | 04:56 PM
rbrettctd's Avatar
Yep 3.54. My 91 is open and it sucks but Im too cheap to do anything about it.
Old Aug 7, 2008 | 06:34 PM
Montana2x2's Avatar
I believe that limited slip and Posi trac are the same thing so you may just need clutches like Wanna said.
Old Aug 7, 2008 | 10:04 PM
user name's Avatar
he's right limited slip=posi trac just different names for the same thing. Yours is more than likely just wore out and needs new clutches like they said before.
j
Oct 12, 2003 11:25 PM
NWDave
Mar 13, 2003 05:58 PM
dansdad
Jan 10, 2003 08:10 PM
parscomm
Jan 3, 2003 11:28 AM
PADZZ
Nov 20, 2002 11:17 PM
