1st gen suspension and brake line upgrades ???
Old Aug 7, 2014 | 03:54 PM
1stgenctd's Avatar
Hi i recently purchased a 1991 w250 ctd and i am doing alot of work to the truck to make it nicer as an everyday driver. First i am having the frame media blasted and epoxy coated before i put new parts on. the truck rides really rough and was wondering if any suspension upgrades can be made to make it ride a little nicer.(I am putting new shocks on it.)Also I am wondering if the leafs are worn because the top of the tires are pointing inward or is that normal?-the ball joints are good. And for the brakes i am having a hard time finding a full pre bent brake line kit preferably stainless.
Any help is appreciated Thanks.
Old Aug 7, 2014 | 06:03 PM
mknittle's Avatar
Every body has different opinions on suspension. some good some not so some expensive others not.
I am eventually going to do the 52" shevy rear spring swap on my front. and a shackle flip on the rear. I am trying the D250(2WD) springs on my rear. but it will be awhile before my 4X4 conversion is complete.
I don't know of any ready bent brake line kits. Stainless can be tough to work with. NiCopp is much easier to bend and is corrosion resistant.
Old Aug 7, 2014 | 06:46 PM
Your wheels pointing inwards is most likely due to your king pins being worn out. The 4wd truck don't have ball joints. And I would suspect that you need new more then a few new parts in the front end as well.
As for soft ride front springs. I bought a set of "soft ride" springs from a local company, They also sell on-line....
http://customsuspension.com/
..few other guys have run them as well on their trucks. My opinion on these springs is that they are NOT softer then the OEM springs.
Old Aug 7, 2014 | 09:07 PM
jerseybud's Avatar
If you are expecting a smooth ride, you got the wrong rig. That said there are a couple of tricks people have tried and posted about here.
Inline tubing has kits for pretty much everything. Sorting thru the catalog is a chore though.
http://inlinetube.com/Preformed%20Li.../DT-CAT-02.htm
I ordered a kit from them 5 years ago- nice stuff, fit perfect. The long frame rail line was especially nice. I got regular steel and coated with crc marine anti-corrosion protectant. Stainless is pretty tough stuff to avoid leaks with.
The w250 sets should fit any diesel- lines should fit any truck with a Dana 60 front and Dana 60/70 rear. As far as I know only differences are in the proportioning valve between the 88-89 (or is it 90?) trucks and 91-93s
Old Aug 7, 2014 | 10:52 PM
That was some great info...and link...Thanks!!
Old Aug 7, 2014 | 11:28 PM
archer2's Avatar
I put that Inline tube brake line kit on about 6yrs ago, in stainless, and never looked back, great fit and no more corrosion.
Old Aug 8, 2014 | 08:33 AM
mknittle's Avatar
interesting read on one solution for the front springs.
http://www.1stgen.org/viewtopic.php?...17993fbadb6b6d
Old Aug 11, 2014 | 09:21 PM
1stgenctd's Avatar
Thanks for the help i am looking into all of your suggestions.
92GhostRyder
Sep 16, 2018 12:02 PM
SkyHarborCowboy
Nov 20, 2012 08:58 PM
countryboy_660
Nov 3, 2012 11:11 AM
77machomopar
Jul 15, 2009 04:56 AM
pulltilbroke
Apr 10, 2009 02:08 PM
