1st gen died electrical
Old Sep 10, 2015 | 05:02 PM
kiszka6911's Avatar
Driving back from lunch today, hit a huge Michigan pot hole. The radio, ignition, gauges, and fuel solenoid, emergency flashers are dead. I have battery power, blower fan, etc. I am thinking fusible link?
Old Sep 10, 2015 | 05:11 PM
kiszka6911's Avatar
Forgot to mention fusible links replace with new ones, checked with meter and have power through them.
Old Sep 10, 2015 | 08:34 PM
MARF75's Avatar
You posted this in the classifieds.
Old Sep 11, 2015 | 08:39 AM
patdaly's Avatar
Fixed..........
Old Sep 11, 2015 | 09:37 AM
Philip's Avatar
Pull the covers on the column and see if the connection to the bottom of the multi function switch is good. I have seen those connectors burnt. That hole could have knocked it loose.
Old Sep 11, 2015 | 01:18 PM
kiszka6911's Avatar
I will check it when I get home, this sounds to be the most plausible. Thanks.
Old Sep 12, 2015 | 10:46 PM
Philip's Avatar
You find anything around the multi function switch??
Old Sep 13, 2015 | 07:35 PM
kiszka6911's Avatar
The plug inside in the column was plugged in. Checking with my meter I have power on the pink wire. +12.7 volts to ground and to the black wire right next to it. When I turn the key on I don't find power on any other wires. I need to study the service manual so I can determine whats up. Not sure why the insulation is so stripped back it appears the harness was made this way.
Column Wires
Old Sep 13, 2015 | 08:21 PM
Philip's Avatar
I haven't looked in a manual yet. I think that large red wire is supposed to hot all the time. Its a power feed. The switch has two power feeds.
Old Sep 14, 2015 | 09:30 PM
kiszka6911's Avatar
Checked the red wire into the key switch no power. I have to check it back to the battery.
92GhostRyder
Sep 16, 2018 12:02 PM
Skiddplate
Aug 24, 2013 04:33 AM
Farmboy12357
Jul 7, 2012 05:12 PM
pulltilbroke
Apr 10, 2009 02:08 PM
