1992 auto
Old Feb 6, 2024 | 05:44 PM
willy wagon's Avatar
1992 auto
i have posted before about this. looks like going to install 2nd gen rad and intercooler in my 92. now i have the intercooler already. in serching for a rad i see two and 3 core available for the 2nd gen trucks. can anyone tell me if stock for that year was 2 or 3 row? also any suggestions as to what may be the best rad as far as reliability and cooling goes? cold case make a big 2 core all aluminium they claim cools very well? 2nd gen is quite a bit bigger but is also aluminium vs cooper which diiapates heat better. thanks for any info
Old Feb 7, 2024 | 04:53 AM
KRB's Avatar
KRB
I'm thinking my 92 IC rad is a 3 core. But it's dark out right now... I'll check when I head out here in a bit but probably can't reply back until tomorrow morning though.
Old Feb 7, 2024 | 08:23 AM
cougar's Avatar
Mine is 3.
Old Feb 7, 2024 | 10:25 AM
u2slow's Avatar
I suggest comparing the actual core thickness (not the tank/header width). I struggle to think there are std/nominal tube sizes/rows any longer.
I also have a 2ndgen rad and IC for mockup. I'm not liking the hackwork it would take to fit an IC rad support. Its going into a gas rad support instead.
Old Feb 13, 2024 | 03:08 PM
1992 one ton
so my neighbour brought over a damaged 2ndgen rad i can use for mock-up. i notice it looks like cores are almost i inch there are two rows. i so will compare tomorrow 1rst gen to 2nd gen. i suspect for any given dimension the 2nd gen rad will hold more fluid, never mind bieng a bigger rad in size. so those that have done this swap have you noticed a difference in cooling? and to what extent , a little none, or quite a difference? would like to hear from you thanks. i havent looked at the gas rad support as to how it would work for the swap?
Old Feb 14, 2024 | 03:46 PM
u2slow's Avatar
I have a manual trans, so I don't have a cooling issue. I do want the bigger intercooler.
The gas vs intercooled rad supports have the vertical stiffeners in different places. The 2ndgen IC in/outlet land right on the intercooled stiffeners, whereas it reaches around them on the gas (and non-intercooled). The IC supports are a desireable item that i don't want to hack up.
My plan is to use the whole 2ndgen support 'hoop' and weld it into the 1stgen rad support. Then the IC and rad are bolt-in.
Old Feb 14, 2024 | 07:26 PM
1992 one ton
i have an 85 gas rad support will check it out. thanks. i would to like to get a second gen rad support, and check it that may be a better option in the end. havent done any cutting yet.
willy wagon
Oct 14, 2023 05:06 AM
mhuppertz
Aug 25, 2020 06:04 PM
sdmark
Cummins Conversions
Apr 6, 2012 10:11 PM
cougar
Apr 12, 2011 03:21 PM
65fury
Feb 13, 2009 11:11 PM
