1992 auto
Old Oct 5, 2023 | 08:48 PM
willy wagon's Avatar
1992 auto
this winter hope to install bigger rad in truck, need better cooling. any advice and results from those who have done this? already have the bigger dodge intercooler.
Old Oct 6, 2023 | 05:49 AM
I see a guy a the Carlisle show every year that fit a 2nd gen radiator into his '92/'93 Cummins truck.
It will work with the larger 2nd gen intercooler I am assuming your are talking about already having.
If it was me I would be looking at adding an extra fan cooled transmission cooler [like the OEM dealer option] as that is the likely culprit of your excessive heat.
Old Oct 6, 2023 | 10:16 AM
so as a rule my trans does not get that bad, as i have a gague for it. that bieng said i think a am going to delete the trans tank and lines that warm up the tranny on cold days.
Old Oct 6, 2023 | 10:51 AM
I would not suggest removing the factory OEM heat exchanger from your auto truck. If you do not have a problem with your auto getting hot, you very likely will after removing the exchanger.
That is the main way your auto is cooled. That little plate cooler behind your grille is not enough.
Old Oct 6, 2023 | 11:34 AM
u2slow's Avatar
The 2ndgen rad is the direction I'll be going too.
Old Oct 6, 2023 | 04:08 PM
thanks for that i thought it just was for warming up the tranny faster. i have a big aftermarket good cooler in it now.
Old Oct 14, 2023 | 05:06 AM
DaishaKrajcik's Avatar
Thanks for the info, I appreciate it.
crunchybuttr
Jul 1, 2013 09:40 AM
dingydoge
Jun 10, 2007 09:21 AM
keithplacervill
Sep 29, 2005 04:06 PM
Twogun
Oct 23, 2004 02:59 PM
shorthair
Dec 25, 2003 07:23 PM
