1990 D250 to W250
Old Mar 19, 2015 | 12:21 PM
  #586
Originally Posted by Alec
For the NV4500:
4LO 1.96, 3HI 1.67, 5LO 1.45, 4HI 1, 5HI.74
That is how you shift if you want to use the t-case to split.
It is not very progressive -- that is, the "gaps" between the gears are not all the same, and the shift from 5lo to 4hi is still pretty big. Worse yet, the 3hi to 5lo shift requires you to shift the transmission from 3-5 before you can double the input speed on the t-case to make the downshift from hi to lo.
I can't make these shifts in any way fast enough for it to be worth doing with a load.
Thank you...That pretty much answers my question. I thought to myself that it seemed too good to be true when I first came across that info.
Thank you to all who posted up comments and info.
Old Mar 21, 2015 | 12:30 AM
  #587
Originally Posted by mknittle
I went to pick n pull today and drug this morning and drug this and the steering box that goes with it home. I couldn't pass it up as the front sheet metal was gone off the truck
That looks familiar...... Hmmmmm.... I wonder where I saw that hunk of metallic engineering goodness before .....
Hmmmmm.... It will take me a minute...
Old Mar 21, 2015 | 08:56 AM
  #588
mknittle's Avatar
Yes you are one of the guilty parties.
From the first time I saw that hokie plate I didn't like it.
Old Mar 21, 2015 | 10:15 PM
  #589
mknittle's Avatar
The last couple days I just did a couple little things.
First I mounted the transmission crossmember braces and adjusted a little more on the transfercase shifters. I also got the steering box bracket about half cleaned up and derusted.
Old Mar 21, 2015 | 10:32 PM
  #590
bobva's Avatar
What changed your mind?
Old Mar 21, 2015 | 10:50 PM
  #591
mknittle's Avatar
I mean the stamped POS. It just looks like trouble.
I am happy with my decision to do the conversion to the RR steering box.
I drove(I mean herded) my dad's 89 W250 Thursday that really reminded me that the stock steering sucks.
Old Mar 21, 2015 | 11:20 PM
  #592
I have a friend down in Portland OR who has gathered all the parts I need to do the RR steeing box conversion....just need to find the time to drive down and get the stuff.
I'll be watching with a bit of jealousy....
Old Mar 22, 2015 | 07:58 AM
  #593
UPS works quite well, you know....
Very happy with my RR steering setup. Never looked back.
Old Mar 22, 2015 | 08:47 AM
  #594
mknittle's Avatar
After bobva posted to change the valve in the back of the pump to the old style it should be a bolt on.
You will probably have to drill out the holes in the bracket though.And if you swap the valve in the pump the stock 1970s hoses should fit without modification.
Old Mar 22, 2015 | 08:50 AM
  #595
mknittle's Avatar
Isn't your truck lifted a little?
Old Mar 22, 2015 | 09:29 AM
  #596
2" or so.. Doesnt affect the RR at all.
Old Mar 22, 2015 | 10:02 AM
  #597
mknittle's Avatar
It wouldn't be hard to correct for a 4" and have good drag link geometry. I think better than a crossover.
Once I get caught up I may look for a steering arm to weld up the tapered hole and re drill it and put the taper on the top.
Old Mar 22, 2015 | 10:26 AM
  #598
PapeCAT's Avatar
If you went 4" you might have to experiment with a steering knuckle block ala
Skyjacker Suspensions SB60 Steering Block Steel Open Knuckle Dana 60 Each | eBay
Old Mar 22, 2015 | 11:24 AM
  #599
bobva's Avatar
You will have to drill out the holes in the bracket though.And if you swap the valve in the pump the stock 1970s hoses should fit without modification.
Its all bolt on.
Just ream the 3 holes on the bracket and the 2 on the chevy shaft.
The SAE hoses come strait off the NAPA shelf. NO BENDING
I have no idea why NJT went with metric box, pump, lines
Old Mar 22, 2015 | 01:50 PM
  #600
mknittle's Avatar
This morning I got a flow control valve from a early 70s Buick.
for the sae hose to the pump adapt.
