wvo
Old Jul 15, 2005 | 11:03 PM
pittom's Avatar
wvo
did my first batch of bio no good, oil was to cold, took pic of process will post tomorrow if i get a chance. still have to wash it but will put pic on here and on my web site. starting to set up for big batches.
Old Aug 12, 2005 | 10:19 AM
mdryan's Avatar
Depending on what went wrong you can fix most bad batches of biodiesel.
Provide more info and pix and I'll advise.
Mark
Old Aug 12, 2005 | 11:24 AM
apwatson50's Avatar
How could you tell it was no good? I'm starting to collect parts for my own processor.
Old Aug 12, 2005 | 05:18 PM
BoostdCTD's Avatar
I don't see how having it to cold could have caused a bad batch, just seems like it'd have to mix longer to complete.
Color / clarity?
Old Aug 13, 2005 | 09:51 AM
pittom's Avatar
You are correct it was cloudy,just took longet. Just ran some in truck and was not as loud and the smoke was not as black with wot.Going to make a bigger patch with used oil not.
Old Aug 13, 2005 | 03:57 PM
kd460's Avatar
Good luck with the bio. Start small, get good at it, then go to bigger batches. I am working on a new processor that is an old propane tank. It holds about 25 gallons (100 lb tank). Was a little nervous with the first few welds, but I left the tank open for a few weeks, flushed it with soap and the power washer 3 times and let it sit again for awhile. The tank is almost done, just trying to come up with the bast way to mix the bio, I want to keep the system totally closed. Picked up a new pump for it today.
The biggest problem I have is getting oil!! I have made up flyers and drop them off on my way home from work. Geez, these guys act like it is gold or something! I tell them I will take it away for free, and still get the puzzled look. 10 flyers out this past week, and no calls yet.
Well, all I can do is keep trying. Good luck with the bio, and I am more than willing to help answer any questions. While I don't claim to know it all, I have been making the stuff for about 2 years. It's not too hard. Seems like the interest is higher along with the fuel prices.
Maybe it's time for a alternative fuels discussion heading/forum here at DTR?
Kevin
Old Aug 13, 2005 | 04:48 PM
mdryan's Avatar
Here's a good design for a "washing" tank.
http://www.utahbiodieselsupply.com/p...firstwashtank/
Good Luck
Old Aug 13, 2005 | 08:16 PM
kd460's Avatar
Yes, thats a good one. There are lots of good sites out there. I found this site to be the most informitive from the technical side of it:
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
Lately, I have done a combination of initially "reverse washing", followed by mist washing, then finally, bubble washing. I can have bio clean in about 3 hours if I really push it. Some report even faster times.
All of those terms I just used are explained on the above link. There is a learning curve, just have to keep at it and read allot, and ask allot. Kevin
Old Aug 13, 2005 | 09:27 PM
mdryan's Avatar
That's a pretty quick turn around.
What exactly is reverse washing?
Old Aug 13, 2005 | 11:04 PM
kd460's Avatar
http://biodiesel.infopop.cc/groupee/...51/m/971104955
Old Aug 24, 2005 | 07:55 AM
pittom's Avatar
kd460 how do you have your setup for making it?
Old Aug 24, 2005 | 10:43 AM
akghound's Avatar
Question WVO vs. Bio
I see you guys are talking about Bio-diesel, a product that can be made from Waste Vegetable Oil (WVO) or Virgin Vegetable Oil, [sometimes refured to as Straight Vegetable Oil (SVO).]
The reason for this post is to mention that some of us are running on WVO that has not been converted to Bio-diesel. Being more mechanical minded and not into chemistry I opted for the WVO route for an alternative fuel. So far I have logged just under 22k miles,running it for a year now.
For more information on how this is done check out;
http://www.frybrid.com/test.htm there is a forum available there as well.
For a good site on how to get started with WVO check out the first two posts at;
http://biodiesel.infopop.cc/eve/ubb....51&f=159605551
I'm not affiliated with Frybrid or Infopop in any way. However I have purchased valves from Frybrid. The best on the market IMHO.
I'm just completing a new set of schematics on converting the 12 valvers. I offer these free to anyone interested. I should have them available by the end of the week. I have sent out many schematics of the orinional setup, these new ones are for an improved setup using 3-port valves rather then the 6-port Pollak Valves.
E-adderss in my profile.
Ken Gardner
walexa
Sep 7, 2005 11:40 PM
screaminbanana
Jul 25, 2005 07:30 PM
Bobcat698
25
Jul 18, 2005 10:08 PM
durasmack
Jul 14, 2005 04:16 PM
high country
Mar 8, 2005 01:12 PM
