Will a NV5600 fit 95 12V
Will a NV5600 out of a 2001 4x4 fit into a 1995 12V that is a auto? I have found a NV5600 w/ bell housing, transfer case, drive shafts, etc. Will it work w/ out a whole bunch of problems? Thanks for any help!
Its a pretty popular swap, and not very hard. The worst part about yours would be cutting the whole in the floor imo. You may need to alter the clutch set up too, depending on what you have. I sent my disc back to peter at south bend to change the hub , cause I already had a good south bend clutch behind my 12 v.
It cost me about 3000 even total and from what I read, Im on the lower end of teh scale, so if you can do it for that or less your probably doing pretty good.
My buddy has a 96 12V. He too put a NV5600 behind it, he sait it wasnt a bad install just a little time consuming at points... But he said he would do it again, Completly different truck compairing it to the stock slush box!
Thanks! I picked up all the parts today. Got it all w/ the exception of a slave?master cylinder for $2400. Now I have to decide on new clutch or the one the came w/ it.
04 cummins 2500 6-speed 4x4
95 12v 2500 4x4 auto soon to be 6-speed
cuminsplowboy1 (11-02-2020)
thebestofindica
04-26-2007 04:25 PM
CTD2001
02-03-2007 01:30 PM
