where is the fuel shut off selonoid?
Old Feb 17, 2008 | 07:57 PM
Silver 002's Avatar
basically where is this fuel shut off selanoid?
Old Feb 17, 2008 | 08:08 PM
boostedte37's Avatar
under the injection pump just over the driver side shock tower
Old Feb 17, 2008 | 08:09 PM
Silver 002's Avatar
k thanks man
Old Feb 17, 2008 | 08:11 PM
the relay for the solenoid is under the cowl and above the fuel filter canister, its hidden so you will need to dig through the wire loom. if thats the problem I replaced mine with a PAC brand 80amp relay/solenoid similar to a Ford starter solenoid..
Old Feb 17, 2008 | 08:48 PM
Silver 002's Avatar
so i looked before i got your diagrams but i didnt find it which way do you pull that plunger to get it to start?
Old Feb 17, 2008 | 09:27 PM
Dartmouth 12V's Avatar
When the plunger is up, the fuel is on, when it is down, the fuel is off. Since it is a solenoid, it retracts(up) when you start it.
Old Feb 17, 2008 | 10:13 PM
pull it up to start
Old Feb 17, 2008 | 10:31 PM
strokerace's Avatar
Before you go buying parts, look at the positive post on your drivers side battery, there is a blue wire which is a 16 gauge fusible link. It will sometimes burn up which is what mine did, I thought that my relay or solenoid was out but it was just that wire. Its an easy free place to start. Heres a good site for parts and diagrams. http://www.fostertruck.com/dodge/default.htm
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
Dean Snow
Sep 26, 2007 03:40 PM
Jones250
Apr 29, 2007 05:18 AM
wcialrlter
Oct 21, 2006 12:51 PM
