What is wrong with my tranny???
Old 01-12-2004, 04:15 PM
LanceD's Avatar
ok, first off it won't shift into park anymore. you have to push up really hard on the shifter to get it to stay in park, and I can not start my truck in park, I have to shift it into neutral to start it. I checked the column and the linkage that goes to the trans, and all that is fine. I think its something inside the tranny. Second, it won't shift out of first gear unless I let off the throttle. it doesn't matter how much gas youre giving it either. it won't shift. Has my transmission gone south?
thanks!
Old 01-13-2004, 09:10 PM
LanceD's Avatar
nobody has this problem?
Old 01-13-2004, 09:43 PM
kandgo's Avatar
Well I hate to see help posts go unanswered so here is my 2 cents,in your signature I notice a TC switch, how many times{ if }any have you let it chug a lug with it locked up? Do you use it as some will say here responsibly? I am saying this as when it is used it is hard on the trans when shifting up thru the gears and when letting it lug down when forgeting to switch it off would and could do some damage to your trans. If all the linkage's are ok it has to be in the trans. As far as the shifting out of first,sounds like a Govenor solenoid/press. transducer problem. You might have some luck calling one of the popular trans guys that most use here on this site. Goodluck, Rick
Old 01-13-2004, 09:50 PM
infidel's Avatar
Since you say it won't start in P it seems to me it must be a linkage problem.
Old 01-14-2004, 05:57 PM
MnTom's Avatar
By chance did you check your engine mounts and the tranny mount? If they move it could move things enough to give you problems.
Tom
Old 01-14-2004, 06:17 PM
amartinson's Avatar
Not to be the bearer of bad news, but that's exactly what mine did.
$3000 trans rebuild
Hope you are luckier than I was!
Old 01-14-2004, 06:54 PM
LanceD's Avatar
I can't let it lug down, because when I tap the brake it unlocks because I have it wired up to the brake switch too. I have locked it up a little early once or twice to smoke someone out bad but only once or twice. most of the time I drive to work and back, and not on the highway.
Old 01-16-2004, 09:58 AM
MCummings's Avatar
Mis-adjusted TV Cable, and Gear Selector on the tranny. Look for loose nuts around the tranny (don't need crazy people under your truck , and then, make sure the gear selector arm is not loose.
The 1st Gear problem, sounds like a TV Cable going out of adjustment, or a dirty solenoid in the tranny.
Merrick
Old 01-17-2004, 11:23 AM
LanceD's Avatar
is the TV cable adjustable without going inside the tranny?
Old 01-17-2004, 03:17 PM
MCummings's Avatar
Yes,, But,, don't ask me how. I've never had the privledge of doing one.
Might want to look here on the forums. I think they have an article on how to adjust the Throttle Valve Cable.
www.DieselTrans.com
Merrick
Old 01-17-2004, 04:28 PM
infidel's Avatar
TV cable adjustment here -
http://dodgeram.org/tech/transmissio..._lever_adj.htm
Old 01-17-2004, 06:10 PM
MCummings's Avatar
Thanks. I couldn't remember where to find a tech.
Merrick
Old 01-19-2004, 09:57 PM
LanceD's Avatar
thanks! I will give that a try.
nelly
06-10-2010 06:51 PM
Black Dog
12-03-2009 08:18 PM
supersheep06
12-13-2007 10:11 PM
HorseHauler
09-05-2004 03:55 PM
jman4567
04-22-2004 10:15 AM
Quick Reply: What is wrong with my tranny???
