What injection pump does a 96 auto $WD have?
Old Apr 9, 2013 | 03:27 PM
mtdoragary's Avatar
What injection pump does a 96 auto 4WD have?
How can I identify which pump I have?
Old Apr 9, 2013 | 03:43 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
If it hasn't been changed...A 180 pump.There is a tag in front of the pump...I think it's the CPL number...
Old Apr 9, 2013 | 05:41 PM
Tate's Avatar
Tag under the throttle linkage bracket is the one you want. 10 digit number, 0 402 736 XXX. Last three digits should be either 885 or 911, likely the former.
Old Apr 9, 2013 | 07:13 PM
mtdoragary's Avatar
Which pumps are good and which are bad?
Old Apr 9, 2013 | 08:00 PM
Tate's Avatar
In what context? A pump that works is a good pump. If you're talking about mild level, easy to get hp, DIY mods, a 215 pump is hard to beat. 600-800 hp, any of the dodge 12mm pumps will work after a pump shop maxes it out. Above that, the 180 seems to be the best with the asymmetrical cam and flat top plungers. But at that point, a 13mm would be preferred with its higher injection rates.
Old Apr 9, 2013 | 08:25 PM
mtdoragary's Avatar
In the context of heavy towing and maximum reliability and fuel economy. I'm beginning to get the drift that a timing bump to 16 may be all I will want to do while running the stock auto tranny. Haven't measured my exhaust yet - may already be 4".
Old Apr 9, 2013 | 08:26 PM
Tate's Avatar
They are all about the same, in that regard.
Old Apr 9, 2013 | 08:31 PM
mtdoragary's Avatar
Thanks!
tommurray
Feb 23, 2014 10:38 AM
cbrxxtreme
13
Jan 26, 2007 06:22 PM
turboost
22
Jul 21, 2005 08:09 AM
routerguy99
17
Aug 11, 2003 12:21 PM
